Originally posted by csa "All Gimbal roads lead to the Katana."
Perhaps for you; but for that price I could have a K3! I'm on a very limited budget, say Social Security; and while I know the highest priced things tend to be the best; I really would like to afford to eat for the next 6 months!
I guess I had thought I would get suggestions in the price range I could afford.
I started with one of the eBay units and ultimately bought a Katana myself.
All of the lower priced units seem to be the same clones of each other, the next step up is much more expensive.
In looking at the Opteka, and reading the reviews, I get the sense that Opteka just buys whatever generic gimbals it can get its hands on and slaps its name on it.
For example, the picture shows an uncoated metal unit, but reviews state that it is rubber coated.
I suspect that they are the same units that are being sold for $79 elsewhere, so if you want to just start out with items in that range get the $79 version as it will probably turn out the same.
With some DIY effort you can probably get it to perform better than new, as described in the reviews.
With the one I bought I did end up taking it apart and sanding down a washer and adding some lubricant and it was much smoother, but I could never cure the issue that when I loosened the swing knob it would droop ever so slightly.
That's when I decided to cut my losses and invest in a better gimbal.
I think these will all work similar to the Opteka based on the critical reviews.
camera gimbal head | eBay
And the BK-45 can be ordered from China much cheaper.
