11-08-2015, 06:14 PM   #46
patarok's Avatar
QuoteOriginally posted by derekkite Quote
The API is exposed in the html. It is reasonably simple to access. The challenge is writing something useful. I've had ideas and looked around a bit but got more interested in something else.
So you would need an idea on what to write for the card?
Or you are "just not interested anymore"...
01-01-2016, 06:32 PM - 1 Like   #47
Extracted Pentax Flucard 'index.html' file
For anyone still interesting this Flucard, I'm late to the party, and trying to figure out how it controls K-3/K-3 II to take photos.
Here is the 'index.html' file from the Pentax Flucard. I extracted it from the firmware, 00.01.00.02, and decoded using 'html' program on the firmware by command 'html decode', which I found from reverse engineering the command. Reformatted in Atom editor, so it's readable.
Here it's:
https://gist.github.com/twang2218/32acd410a8c1875101b3
Here are some interesting strings:
PHP Code:
            var comuHTTPResponseError "responseError";
            var
comuHTTPResponseNullError "responseNullError";
            var
comuHTTPTimeoutError "timeoutError";
            var
comuHTTPMotionJpegError "motionJpegError";
            var
comuHttpRequestLiveview "/mjpeg_video?action=stream";
            var
comuHttpOperationRequest "/cgi-bin/host_operation";
            var
comuHttpResponseErr "err=";
            var
comuHttpRequestAf "?action=af";
            var
comuHttpResponseAf "af=";
            var
comuHttpRequestShutter "?action=shutter";
            var
comuHttpResponseShutter "shutter=";
            var
comuHttpRequestCapture "?action=capture";
            var
comuHttpResponseCapture "capture=";
            var
comuHttpResFileName "file=";
            var
comuHttpResDirectory "directory=";
            var
comuHttpResDate "date=";
            var
comuHttpRequestLiveviewStop "?action=live-view-stop";
            var
comuHttpResponseLiveviewStop "live-view-stop=";
            var
comuHttpRequestLiveviewPause "?action=live-view-pause";
            var
comuHttpResponseLiveviewPause "live-view-pause=";
            var
comuHttpRequestLiveviewRestart "?action=live-view-restart";
            var
comuHttpResponseLiveviewRestart "live-view-restart=";
            var
comuHttpRequestLiveviewZoom "?action=live-view-zoom";
            var
comuHttpResponseLiveviewZoom "live-view-zoom=";
            var
comuHttpRequestHorLowMode "?action=hor-low-mode";
            var
comuHttpResponseHorLowMode "hor-low-mode=";
            var
comuHttpRequestHorActiveMode "?action=hor-active-mode";
            var
comuHttpResponseHorActiveMode "hor-active-mode=";
            var
comuHttpGetParameter "?action=get-camera-config";
            var
comuHttpGetCapability "&config-entry=capability";
            var
comuHttpResCapability "capability=";
            var
comuHttpGetStatus "&config-entry=status";
            var
comuHttpResStatus "status=";
            var
comuHttpGetBattery "&config-entry=battery";
            var
comuHttpResBattery "battery=";
            var
comuHttpGetExposureIndex "&config-entry=exposure-index";
            var
comuHttpResExposureIndex "exposure-index=";
            var
comuHttpGetFnumber "&config-entry=f-number";
            var
comuHttpResFnumber "f-number=";
            var
comuHttpGetShutterSpeed "&config-entry=shutter-speed";
            var
comuHttpResShutterSpeed "shutter-speed=";
            var
comuHttpGetExposureBiasComp "&config-entry=exposure-bias-compensation";
            var
comuHttpResExposureBiasComp "exposure-bias-compensation=";
            var
comuHttpGetCaptureMode "&config-entry=capture-mode";
            var
comuHttpResCaptureMode "capture-mode=";
            var
comuHttpGetDriveMode "&config-entry=drive-mode";
            var
comuHttpResDriveMode "drive-mode=";
            var
comuHttpGetAfMode "&config-entry=af-mode";
            var
comuHttpResAfMode "af-mode=";
            var
comuHttpGetSdStatus "&config-entry=sd-status";
            var
comuHttpResSdStatus "sd-status=";
            var
comuHttpGetSdRecordCount "&config-entry=sd-record-count";
            var
comuHttpResSdRecordCount "sd-record-count=";
            var
comuHttpGetHyperMode "&config-entry=hyper-mode";
            var
comuHttpResHyperMode "hyper-mode=";
            var
comuHttpGetShiftMode "&config-entry=shift-mode";
            var
comuHttpResShiftMode "shift-mode=";
            var
comuHttpGetLVStatus "&config-entry=LV-status";
            var
comuHttpResLVstatus "LV-status=";
            var
comuHttpGetLiveviewResol "&config-entry=live-view-resolution";
            var
comuHttpResLiveviewResol "live-view-resolution=";
            var
comuHttpGetLanguage "&config-entry=language";
            var
comuHttpResLanguage "language=";
            var
comuHttpGetCommunicationParameters "&config-entry=communication-parameters";
            var
comuHttpResCommunicationParameters "communication-parameters=";
            var
comuHttpResCommunicationParametersSSID "ssid=";
            var
comuHttpResCommunicationParametersNetworkKey "networkkey=";
            var
comuHttpResCommunicationParametersChannel "channel=";
            var
comuHttpResCommunicationParametersUserSetting "user-setting=";
            var
comuHttpGetVersionParameters "&config-entry=version-parameters";
            var
comuHttpResVersionParameters "version-parameters=";
            var
comuHttpResVersionParametersCamera "camera-version=";
            var
comuHttpResVersionParametersCard "card-version=";
            var
comuHttpResVersionParametersHTML "html-version=";
            var
comuHttpGetStreamFrameResol "&config-entry=stream-frame-resolution";
            var
comuHttpResStreamFrameResol "stream-frame-resolution=";
            var
comuHttpGetFocusArea "&config-entry=focus-area";
            var
comuHttpResFocusArea "focus-area=";
            var
comuHttpGetFocusFrameSize "&config-entry=focus-frame-size";
            var
comuHttpResFocusFrameSize "focus-frame-size=";
            var
comuHttpSetParameter "?action=set-camera-config";
            var
comuHttpSetExposureIndex "&exposure-index=";
            var
comuHttpSetFnumber "&f-number=";
            var
comuHttpSetShutterSpeed "&shutter-speed=";
            var
comuHttpSetExposureBiasComp "&exposure-bias-compensation=";
            var
comuHttpSetLiveviewResolution "&live-view-resolution=";
            var
            var
comuHttpSetCommunicationParameters "&communication-parameters=";
            var
comuHttpSetCommunicationParametersSSID "&ssid=";
            var
comuHttpSetCommunicationParametersNetworkKey "&networkkey=";
            var
comuHttpSetCommunicationParametersChannel "&channel=";
            var
comuHttpSetCaptureResetCondition "&capture-reset-condition=";
            var
comuHttpResCaptureResetCondition "capture-reset-condition=";
            var
comuHttpSetSdActive "&sd-active=";
            var
comuHttpResSdActive "sd-active=";
            var
comuHttpCardCgiFileRemount "/cgi-bin/photo";
            var
comuHttpCardCgiResFileRemount "/DCIM/";
            var
comuHttpCardCgiFileRefresh "/cgi-bin/refresh";
            var
comuHttpCardCgiFileResRefresh "200";
            var
comuHttpCardCgiGetThumbNail "/cgi-bin/thumbNail";
            var
comuHttpCardCgiGetThumbNailDng "/cgi-bin/thumbRaw";
            var
comuHttpCardCgiGetPhotoList "/cgi-bin/photolist";
            var
comuHttpCardCgiResPhotoList "/DCIM/";
            var
comuHttpCardCgiResPhotoListEmpty "No files found";
            var
comuHttpCardCgiParameters "/cgi-bin/card_config";
            var
comuHttpCardCgiGetParameters "?action=get";
            var
comuHttpCardCgiSetParameters "?action=set";
            var
comuHttpCardCgiParametersWifiSSID "wifi_ssid=";
            var
comuHttpCardCgiParametersWiFiKey "wifi_key=";
            var
comuHttpCardCgiParametersWiFiChannel "wifi_channel=";
            var
comuHttpCardCgiParametersAutoWiFi "auto_wifi=";
            var
comuHttpCardCgiParametersCardVersion "card_version=";
            var
comuHttpCardCgiGetResParameters "wifi_ssid=";
            var
comuHttpCardCgiSetResParameters "OK";
            var
comuHTTPCardCgiGetStatus "/cgi-bin/card_status?action=get";
            var
comuHTTPCardCgiResStatus "m1=";
            var
comuHTTPCardCgiReqRestoreControlImage "/cgi-bin/restore";
            var
comuHTTPCardCgiResRestoreControlImage "OK"
And there are more of how each request url formed in many following functions. such as:
PHP Code:
            function captureOnloadShutter() {
sysSetLog("[BUTTON] SHUTTER: onload");
                if (
captureButtonActive == 1) {
                    if (
captureLiveviewStatus == 0AJAX_get(comuHttpOperationRequest comuHttpRequestShutter "&" comuHttpResponseAf "0");
                    else
AJAX_get(comuHttpOperationRequest comuHttpRequestShutter);
AJAX_start_connection_timer();
setTimeout("captureShutterOff()"200);
Last edited by taowang; 01-01-2016 at 06:40 PM. Reason: Add more interesting info from the file
01-04-2016, 02:24 PM   #48
patarok's Avatar
Seems like nice work. If you would team up with some people who have interest on producing a better flucard, you could get money out of it, and we could maybe have a better interface...
05-21-2016, 02:16 PM   #49
Banned
taowang, these strings form part of url. And this part of url is passed to the camera and parsed in camera. There is a list of all possible comfiguration parameters and actions, if you are interested. But these are very restricted comparable to API available with pktriggercord (mass storage device interface).
08-28-2016, 03:52 AM   #50
redcat's Avatar
QuoteOriginally posted by tempelorg Quote
having it connect to my home Wifi network instead of it creating its own.
how did you do that, it's very useful to have it connect to home wifi, that way I can upload photos in the card directly to Instagram via my phone !
08-28-2016, 04:09 AM   #51
Read again, redcat - that was a goal. I never succeeded in that. See post #28 for details.
08-28-2016, 04:19 AM   #52
redcat's Avatar
oh sorry, I was too excited with the hack, didn't read carefully. Thank you for your contribution to this project
11-24-2016, 04:54 PM   #53
amoringello's Avatar
Has anyone run into the problem (or more importantly solved the problem) where cgi-bin/photolist returns only the list of photos on the card when the WiFi was enabled?
Any photos taken since the WiFi was enabled are not listed.
Is there a way to refresh the list?
I have a small Python program that is 90% of the way to getting a basic AutoImporter compatible with LightRoom... similar to the old EyeFi functionality.
But if new files are not detectable without turning WiFi off/on, it is not very useful. :-) :-)
---------- Post added 11-24-16 at 07:19 PM ----------
So, I just tried "cgi-bin/refresh". I have not seen that documented anywhere, but it did what I wanted.
Hopefully I can get the rest working now. :-)
ap, card, care, code, equipment, firmware, flucard, hacks, linux, list, log, pentax, pentax firmware, people, photos, sense, tripod, wi-fi, wifi
Resurrecting Pentax firmware hacking Shodan Pentax DSLR Discussion 765 02-23-2019 05:24 AM
Spider Engineering stubyles Monthly Photo Contests 9 11-04-2014 04:16 AM
Latest Pentax hacking results Shodan General Photography 43 06-05-2014 10:07 AM
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Chinese reverse engineering? ve2vfd General Talk 35 05-29-2009 05:41 AM
All times are GMT -7. The time now is 03:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
