05-20-2015, 06:15 PM   #1
FA31 cheap filters for lens hood and how to remove glass
Hi
I've just ordered the FA31 and read a lot about the lens hood issues, and have decided that the cheap, glass-less, stacked filters option seems to be the best for me. So now I'm wondering where is the best place to get said cheap filters and how to remove the glass from them? (I'm in Melbourne, Australia so shipping from overseas is probably not an option)
Also, if I use an ND filter on it, it would be best to put it directly on the lens before putting the stacked filter hood on?
David
05-20-2015, 06:27 PM   #2
MadMathMind's Avatar
This thing is really the best option:
http://www.amazon.com/%C3%9855-8mm-%C3%9858mm-DMC-FZ18-DMC-FZ28-DMC-FZ35-Con...rds=janco+58mm
There's this one from China:
Metal 58mm Standard Lens Hood with Screw Mount for Canon Nikon Pentax Lens | eBay
Sure looks like the same thing, since you have to remove the inner portion of the Janco one to make it work.
05-20-2015, 06:30 PM   #3
QuoteOriginally posted by MadMathMind Quote
Amazon.com : Janco 58mm lens adapter 55.8mm-58mm for LUMIX DMC-FZ18, DMC-FZ28, DMC-FZ35 and DMC-FZ38 to accept 58MM Filter or Lens Converters : Camera Lens Adapters : Electronics
Thanks, do you know how it works with an ND filter (for example) and also lens cap? The ebay option would be better for shipping costs.
David
05-20-2015, 07:49 PM   #4
The cap doesn't fit over it too well. It does fit and stays but it's not as stable. I'd recommend a pinch cap anyway, since the fancy metal cap can scrape up the sides when you take it on and off, felt be damned. (There was a unit someone on the forum was selling here that displayed this issue.)
Filters just go underneath it. Screw the filter onto the lens, then screw the hood on. It's better that way. The exterior of the Janco one does have 58mm filter threads, but it's not recommended to attach the filter to the outside of the hood. It negates the purpose of the hood, since stray light can just enter the filter. Plus, you introduce a good chance for internal reflections.
05-20-2015, 08:52 PM   #5
Cool, thanks, now to find a lens cap for it then
06-08-2015, 03:44 AM   #6
QuoteOriginally posted by dtra Quote
hmm, turns out that the chinese hood didn't fit between the built-in lens hood, do you know what size lens cap goes on the janco hood? Is it just a standard 58mm pinch cap?
06-09-2015, 06:24 PM   #7
Thanks, I might give that a try if this other hood doesn't do the job.
06-09-2015, 06:26 PM   #8
Yes. Standard 58mm cap.
fa31, fa31 cheap filters, filter, filters, filters for lens, glass, hood, lens, lens hood, option, tripod
Hood for FA31 Ltd nicoprod Pentax SLR Lens Discussion 12 02-22-2014 10:04 PM
How to photo lens glass Banskojoe Photographic Technique 4 07-05-2013 02:03 PM
How to Remove Fungus: A 50mm F1.7 lens adr1an Do-It-Yourself 14 08-30-2012 04:04 AM
How to remove a glass screen protector manishved Pentax Camera and Field Accessories 2 07-19-2011 06:15 AM
How to remove old fingerprint(s) off lens coating roboticspro Troubleshooting and Beginner Help 8 04-21-2011 02:21 PM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
