05-26-2015, 05:37 PM   #1
AF360FGZ II Flash slow-speed sync with K3?
What is the best way to use the slow-speed sync on this flash with K3? I am using the TAv mode, as I could not find a dedicated function on the flash or camera menu in connection with this flash.
Is there another easier way?
05-26-2015, 05:39 PM   #2
isn't it in the flash menu on the 4-way controller?
05-26-2015, 08:37 PM   #3
Oh yes, thank you, I was on the wrong mode.
05-27-2015, 03:02 PM   #4
Lowell Goudge's Avatar
I always use manual mode on the camera with PTTL flash. Set shutter to 1/150 to 1/180 and aperture to give about -1 to -2 stops under expose and let the flash do the rest. Bounce works well indoors as direct flash is harsh
05-29-2015, 06:30 AM   #5
Some modes other than X or M will put the Iso too high.
07-02-2015, 12:54 AM   #6
This is good advice!
af360fgz ii flash, flash, flash slow-speed sync, ii flash slow-speed, slow-speed, sync, tripod
AF360FGZ II Flash batteries mAh value, weather sealing and use with K3 cake Pentax Camera and Field Accessories 6 05-24-2015 09:45 PM
K20D slow speed sync flash mpress Troubleshooting and Beginner Help 3 05-20-2013 08:19 PM
Rear curtain and slow shutter speed flash sync question for the 645D Warped Pentax Medium Format 9 01-28-2011 11:36 AM
Hi speed sync. Only with AF360FGZ and AF540FGZ??? gybp Flashes, Lighting, and Studio 5 03-13-2010 09:23 PM
Blurred pictures with slow-speed sync samiam Pentax DSLR Discussion 8 08-25-2009 11:43 AM
All times are GMT -7. The time now is 12:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
