06-24-2015, 01:23 PM   #1
Ron_Man's Avatar
Wireless Flash Question - How to Make Main Flash Not Part of Exposure?
Hi Guys,
Going to be trying my hand at some wireless flash today. I have in the past used it (K-5 and K-7) and never cared about the main camera flash being a part of the exposure. However, I realize it should be possible? According the my AF540gz manual anyway. I can't seem to find this info the K-3 manual. Can this be done?
I want to just use my AF540gz or AF360gz fire flash off camera but not have the main camera flash to be included in the exposure. Please help me and sorry if this has been covered, I did not see it in search. Thanks guys in advance!
06-24-2015, 01:29 PM   #2
enoeske's Avatar
QuoteOriginally posted by Ron_Man Quote
Hi Guys,
Set the pop-up flash to controller
06-24-2015, 01:37 PM   #3
Ron_Man's Avatar
QuoteOriginally posted by enoeske Quote
Set the pop-up flash to master controller
I've tried both but the pop up flash still shows up in my pictures.
Maybe the question is what mode should the AF540gz be on? I have it set to slave, as that is the only way to get it to fire wirelessly.
Am I doing it right and this is what to expect as the outcome?
06-24-2015, 01:42 PM   #4
UncleVanya's Avatar
I have seen other people comment that despite the promise of not including the pop-up flash in the exposure they have not seen this in practice. In practice they claim the pop-up still contributes to the exposure. Could you try adding a small modifier to bounce this so the off camera flash still sees it but the effect is limited on the subject?
06-24-2015, 01:46 PM   #5
enoeske's Avatar
There is a good discussion here:
https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/161062...-external.html
06-24-2015, 03:02 PM   #6
Otis Memorial Pentaxian
Set your K-3 built-in flash to "Wireless (Controller)" and the AF540GZ to "P-TTL/Slave".
This is in the AF540GZ manual but is confusing. It is only hinted at in the K-3 manual. As noted above, there is still some chance that the on-board flash will contribute to the exposure. It depends on the distances for both the slave and the subject.
06-24-2015, 03:06 PM   #7
IIRC, this is the most common work-around, though it can be tricky to set up.
06-24-2015, 03:16 PM   #8
No matter what mode it is in, master or control, the triggering flash (built-in or attached to the hotshoe) always fires during exposure. Whether it contributes significantly to the exposure depends on distance, ambient light, lens aperture, ....
Don't take my word for it, take a test photo in front of a mirror, with the triggering flash visible in the photo, and see for yourself.
06-24-2015, 05:05 PM   #9
mee
Please correct me if I am incorrect (I know you guys will never hesitate though to show someone wrong haha) But IIRC it has to trigger since Pentax uses an optical triggering method. This isn't an RF setup. The flashes must be in line of sight or at least in a location to pickup the OBF's light.
I'm using a pair of cheap RF triggers to play with remote (off camera) flash. It works well and the whole package was around 20 USD. Search for 'NPT-04' maybe if you get tired of the Pentax solution (I know this a fork in the thread.. but useful enough I thought to mention).
06-24-2015, 05:47 PM   #10
Kozlok's Avatar
Which wireless triggers support PTTL?
06-24-2015, 07:57 PM   #11
QuoteOriginally posted by Kozlok Quote
I've heard that NONE support Pentax P-TTL. There was a deal that Adam highlighted recently for a Cactus flash set-up, but after reading it, I think it didn't support P-TTL but rather a very flexible manual RF setup where you could change flash settings from the remote: Exclusive Cactus Flash and Sirui Tripod Coupon - Deals and Savings | PentaxForums.com
06-24-2015, 09:09 PM   #12
clackers's Avatar
There can be a small amount of the popup flash still present, which might be useful for portrait catchlights, but unwanted in something like a carefully-constructed still-life piece (which you're going to use manual for anyway, rather than P-TTL's guesswork).
06-25-2015, 12:32 AM   #13
max_pyne's Avatar
you can use very cheap radio triggers for manual set-up or get the Cactus V6 that supports Pentax PTTL.
06-25-2015, 07:29 AM   #14
UncleVanya's Avatar
QuoteOriginally posted by max_pyne Quote
I'm not sure that the Cactus supports P-TTL. See manual here: http://www.cactus-image.com/Cactus%20V6%20User%20Manual%20(EN).pdf
One mention of P-TTL in the whole thing and it isn't suggesting that it supports P-TTL in fact it is saying it can only use the TTL control on basic TTL flashes not those that are P-TTL etc.
06-25-2015, 07:40 AM   #15
max_pyne's Avatar
TTL pass-through: The V6 essentially pretends to not be there, thus allowing the on-camera flash to use all its native (P-TLL) features.
Note that pressing the shutter release button on the camera will fire the flash and trigger the V6 only if the shutter speed does not exceed the sync-speed. Unfortunately, Pentax cameras do not use the centre pin for triggering an on-camera flash in HSS mode. It is thus not possible to “steal” the HSS trigger signal, so optical triggering remains the only option for letting manual flashes contribute to an HSS exposure.
---------- Post added 25-06-15 at 16:41 ----------
UPDATE: As of firmware version V1.1.008, the V6 supports the Pentax AF540FGZ II and the Pentax AF360 FGZ II flash models.
Read more at: Cactus V6 Review - Conclusion | PentaxForums.com Reviews
I personally do not miss P-TTL support. Many professionals also avoid the vagaries of automatic metering and prefer manual flashes instead. David Hobby (aka “The Strobist”) once commented on TTL: "...I tweaked them around a lot. I am not used to the on-the-fly variability of TTL (one reason I do not normally use it) so the camera and I were both trying to drive the car."
Ideally, the V6 would still be able to emulate a system-dedicated P-TTL flash on-camera for two particular reasons that are Pentax-specific: It would be able to fool a Pentax DSLR into providing second-curtain sync and HSS trigger events. While the V6 can emulate these features with some manual delay settings and/or the help of a P-TTL capable flash, it would surely be convenient to use these P-TLL extras in a fully automated fashion. However, I personally would certainly not want to pay extra for this convenience. The ability to remote control power levels of off-camera flashes is the main feature of the V6 and I personally would not want it to become more expensive or specific to certain brands in order to have support for these features added.
I value that the V6 is highly brand-agnostic when it comes to supported cameras and/or flashes. In particular shooters that own multiple camera systems should take note of this one system that may address all their needs. I furthermore applaud the fact that the V6 upvalues any previous investments into TTL flashes and preserves the investment in any V5, LV5 gear.
af540gz, cactus, camera, dslr, exposure, features, flash, flash question, guys, hss, ii, k-3, k3, on-camera, pentax, pentax k-3, review, reviews, tripod, v6
How to make Pentax-K5 II work with Canon off camera flash units ? Foma2 Flashes, Lighting, and Studio 15 07-22-2015 09:12 PM
how to make k3 fire flash and auto focus in complete darkness. pentaxk3user Troubleshooting and Beginner Help 9 04-23-2015 08:50 AM
Multiple exposure combined with wireless pttl flash do not work with Pentax K5? 645user Pentax K-5 & K-5 II 10 01-14-2015 03:11 PM
Can we set the internal flash of K-7 not to flash while connecting wireless with 360? raider Flashes, Lighting, and Studio 12 11-15-2009 09:31 AM
How not to test your Cactus Wireless Flash Trigger xs400 Post Your Photos! 7 02-10-2009 07:01 AM
All times are GMT -7. The time now is 05:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
