07-01-2015, 04:52 PM   #1
Pentax 67-special adapter
On my trip to produce a special lens to camera-adapter to use on m67/female-lens-mount(original adapter removed) i have found these: 1. 67 mm reverse adapter. 2. asahi pentax 6x7 67mm. its about the latter which i dont understand where it will be used since the mount is different from the first one which has clearly the camera-mount. see image of no. 2
Canon PowerShot SX130 IS  Photo
07-01-2015, 09:00 PM   #2
Swift1's Avatar
QuoteOriginally posted by europanorama Quote
That looks like the bayonet mount for Pentax 6x7 filters.
07-05-2015, 10:45 AM   #3
gofour3's Avatar
You have a Pentax 6x7 67mm gelatin filter frame, there were also versions in 82mm & 100mm.
You attach the bayonet mount on the filter holder to the front of the lens and the outside part has threads for some older metal screw-in hoods. (90mm/2.8, 105/2.4 & 135/4)
The gelatin filter slides into an opening in the top marked with an orange arrow.
Phil.
adapter, pentax, tripod
Adapter from Pentax 67 lenses to Canon EOS vocalsman67 Pentax Medium Format 11 10-31-2021 02:56 AM
Pentax 67 Lens to Pentax 645 Body Adapter BBC5 Pentax Medium Format 12 10-29-2014 01:05 PM
Adapter for using Pentax 67 lenses on a 645D Photodana Pentax SLR Lens Discussion 4 06-25-2014 02:49 PM
Pentax 67-camera-mount-for special adapter europanorama Pentax Medium Format 2 04-23-2014 05:40 AM
Wanted - Acquired: Pentax 67 to 645 adapter mikeSF Sold Items 9 09-14-2013 04:48 PM
All times are GMT -7. The time now is 04:07 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
