07-08-2015, 05:59 AM   #1
TER-OR's Avatar
OGPS and Flash?
I know the manual says a flash and the OGPS can't be used at the same time. Of course only one thing can occupy the hotshoe. Can a flash be used with the sync cable and have the OGPS active at the same time? There may be times in the field where a flash would be useful but the GPS data is vital. I'm having a tough time finding that information.
07-08-2015, 06:04 AM   #2
I don't believe you can use an external flash with the GPS unit mounted. I guess this is where the K-3 II actually stands apart!
07-08-2015, 06:08 AM   #3
Not a Number's Avatar
Some one tried using the OGPS-1 with a flash on a sync cable and could not get it to work. Perhaps it was just the cable. If I can find the post I'll update with a link.
Here we go - related:
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/290737-pentax...ml#post3190003
07-08-2015, 06:42 AM   #4
Scorpio71GR's Avatar
Since the adapter for the snync cord mounts to the hot shoe I don't see how you could. There is nowhere else to attach a sync cord. Yes the K3ii had the advantage here with built in GPS.
07-08-2015, 07:13 AM   #5
Some sync cords have a pass-through shoe on the camera end. That way you can have a flash on the camera and one on the sync cord or piggy back two sync cords.
The OGPS unit in the hot shoe gets in the way of the popup flash but it could be the digital signals from the GPS unit override or disable flash or at least P-TTL.
07-08-2015, 08:45 AM   #6
The hardware exists to mount the OGPS, and have an external flash connected: "Pentax Hot Shoe Adapter F", for e.g. at Pentax Hot Shoe Adapter F 31022 B&H Photo Video.
I don't have this adapter so haven't tried it to see if the camera would recognize both accessories.
07-08-2015, 09:16 AM   #7
QuoteOriginally posted by realitarian;3306704"Pentax Hot Shoe Adapter F", for e.g. at [url=http://www.bhphotovideo.com/bnh/controller/home?O=&sku=41177-3vy8YCFQmKaQod4GUPuA&is=REG&m=Y&A=details&Q=:
Pentax Hot Shoe Adapter F 31022 B&H Photo Video[/url].
I use this to trigger a wireless remote attached on the hotshoe and a strobe via sync cable so it may be worth a try.
07-08-2015, 09:44 AM   #8
LaurenOE's Avatar
I've done it...a long time ago.
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/152872-o-gps-...ftz-flash.html
07-08-2015, 10:14 AM   #9
QuoteOriginally posted by LaurenOE Quote
Very nice...impressive!! Also kudos for machining your own mounts...a 'hard' skill/process/product for 'delicate' optical instruments.
07-08-2015, 11:14 AM   #10
TER-OR's Avatar
Interesting. I presume for my uses, moving the the K3II would negate the requirement for the adapter and cable, unless multiple flashes are required. The adapter and cable together aren't inexpensive at B&H...
Thanks for the information, though. It's something which might be quite useful, even just for simple flashes.
flash, gps flash, time, tripod
Do you see use for an astrotracer either from ogps 1 or K3-II ? Nicolas06 Pentax SLR Lens Discussion 20 05-24-2015 02:15 PM
LW, reverse macro and internal flash. Flash fire issue SweFin Pentax K-5 & K-5 II 4 09-04-2014 07:23 AM
Wanted - Acquired: Ogps-1 VoiceOfReason Sold Items 8 06-13-2014 03:56 PM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
