07-10-2015, 09:10 AM   #1
slip's Avatar
eyefi mobi pro
How hard is it to select certain photos to transfer with the K3 ? Is it a pain in the a**?
If it is a pain then would I be better off getting the non pro version?
I was also reading that when you transfer a raw image, it first has to be transformed into a jpg with there cloud service...
Anyone know if this is true?
Thanks
Randy
07-10-2015, 01:36 PM   #2
davidreilly3207's Avatar
You can select the pictures with the pro version. They are not automatically converted if you shoot just raw but will transfer jpegs if you shoot raw+jpeg, as it doesn't support raw transfers. To select you set the mode to select and then use playback to select the photos you want transferred the same way you do to delete selected photos.
The pro x2 supports raw as well as 802.11n over the 2.4ghz band only. the rest only support 802.11g and are slower. Here is a link to the features of each type. https://x2help.eyefi.com/hc/en-us/articles/553261.
I use the pro x2 in slot two and shoot raw to slot one and jpeg to slot two and let it transfer the jpegs.
eyefi mobi, pain, transfer, tripod
Which EYEFI card for K3II Shanti Troubleshooting and Beginner Help 10 07-09-2015 01:05 AM
eyefi mobi pro indy Pentax Camera and Field Accessories 15 05-25-2015 02:16 AM
4GB Mobi Eye Fi - doesn't transfer pictures UncleVanya Pentax K-30 & K-50 13 03-26-2015 01:05 PM
Eyefi and K3 Portrait gryhnd Pentax Camera and Field Accessories 7 03-25-2014 08:53 AM
k-30 & EyeFi WiFi SD 16GB Pro X2 tsvetan Pentax K-30 & K-50 15 06-15-2013 04:13 PM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
