08-19-2015, 08:35 PM   #1
Replacement for lost FA 77 lens cap
Any one got any idea about whether the DA 70/2.4 genuine lens cap can be used as replacement for FA77/1.8?
or other genuine limited lens cap than can be used as replacement?
Many thanks.
08-19-2015, 08:59 PM   #2
Why not just buy a lens cap?
Pentax 49mm Metal Lens Cap for FA 77mm f/1.8 Lens (Silver) 31703
08-19-2015, 09:15 PM   #3
QuoteOriginally posted by alamo5000 Quote
Thanks alamo5000, Unfortunately mine is a black copy. I think BP photo got only a silver piece.
Adorara seems to have some 49mm metal caps in stock, but it also shows an image of silver cap, plus the shipping cost is really deterring.
will try eBay for luck.
08-19-2015, 09:36 PM   #4
QuoteOriginally posted by MarcusTH Quote
About $25 bucks and you can get one. I think the 43mm one and the 77mm are the same but I am not sure.
I just googled it and put up the first link I found. I know they have black ones around.
---------- Post added 08-19-15 at 11:41 PM ----------
I also just looked at your profile... you are in Singapore! (nice! I used to live in Singapore)
You can just run down to several stores there and pick one up in person I am pretty sure.
08-19-2015, 10:58 PM   #5
Yup, FA 43mm and FA 77mm caps are of the same size. I have a FA 43mm and did tried its cap on the FA77. There are some guys selling the genuine 77/43mm metal hood on ebay and prices are generally 50/60+.
You are quite right that I probably should drop by the local stores and check it out, before ordering it form overseas.
Singapore is quite nice especially with its close neighbours, but it's just toooo small >_<
By the way, many thanks for ur help and reminder.
cap, fa 77 lens, lens, lens cap, replacement, silver, singapore, tripod
I knew it would happen - lost the lens cap kshapero Pentax Compact Cameras 4 09-30-2013 03:42 AM
What can I repurpose as replacement lens cap for 03 fisheye ens? NotSteve Pentax Q 21 08-26-2013 10:23 AM
Replacement lens cap for SMC-A 1:2 50mm roflzzhaveridges Pentax SLR Lens Discussion 3 05-01-2011 02:01 AM
Lost lens cap on 18-55mm DA L. Can anyone confirm if this eBay cap is the correct one philthy Pentax SLR Lens Discussion 3 10-15-2009 01:26 AM
Replacement Lens Cap for Da 70mm Rondec Pentax SLR Lens Discussion 3 09-19-2009 06:24 PM
All times are GMT -7. The time now is 11:48 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
