02-06-2016, 12:24 PM   #16
max_pyne's Avatar
Otherwise you can hotglue it..
02-09-2016, 08:53 AM   #17
Good idea!
I might try CA glue...
02-09-2016, 12:51 PM   #18
UncleVanya's Avatar
In the same way that the mount on a lens can be removed and added to a Nikon to make it mount on a Pentax K-Mount you can take the mount ring off an old beaten up K-mount camera and drill the appropriate holes to line up with where their existing Nikon version mounts and mount a K-Mount flange on the device. It appears to screw on - should be really simple to convert. Or am I missing something complicated?
I still think the Nikon F mount version plus a couple of eBay, Craigslist, or Goodwill beater K mount bodies or old 2x TC's etc. would permit you to remove the existing Red and chrome parts of the mount (leaving the lens release lever) and align the mount so the release lever lines up (or drill a new one to fit the position) and mount it via screws (you may have to drill the mount to fit the existing holes.
Ideally I would use a K mount not a KA or KAF2 mount to give a simple install.
I wish they made this in M4/3 for my trip to EU. I would probably try it.
12-01-2016, 02:02 PM   #19
bdery's Avatar
I'm reviving an older thread, sorry for that...
Did anyone in fact try this?I'm curious/worried that the release lever would not properly work with K-mount lenses.
12-01-2016, 02:17 PM   #20
UncleVanya's Avatar
I haven't but my thinking was to align the mount so that the pin on the nikon bellows was lined up with the mount hole on the K mount flange. The lens might now be completely right side up at that point but it should be workable. I have a friend who converted his PB-6 Tilt and shift bellows this way but I have no idea of the details and he is sadly deep in dementia at this point.
12-02-2016, 06:17 AM   #21
bdery's Avatar
I'm not familiar with the Nikon mount, I'll have to look into it to better understand your reply.
Considering the need to get two beater Pentax cameras to modify the CaptureLENS, it might be easier to get the Canon version and the 15$ adapters refered to above. Would those allow the lock to engage properly?
That is so sad, I'm sorry.
12-02-2016, 07:05 AM   #22
UncleVanya's Avatar
My reply was confused. I was thinking of a bellows at the time not the CAPTURElens device. I was saying that both have a pinhole and that if the position of the Nikon was off just by angle you could rotate the Pentax mount until the hole lined up. Then you might need to drill new screw holes etc to get it to fit but the button might work. I'm not certain.
capturelens by peak, design, peak, tripod
Peak Design Capture Pro Dropped My K-3 Today Doundounba Pentax DSLR Discussion 29 06-07-2016 11:58 AM
New Peak Design Capture Pro camera-clip owner raves about it fewayne Pentax DSLR Discussion 6 05-28-2014 03:14 AM
Peak Design leash and cuff derekkite Pentax Camera and Field Accessories 1 12-09-2013 06:17 AM
New Leica M design by Marc Newson and Jony Ives richardwong Pentax Mirrorless Cameras 4 10-08-2013 05:59 PM
All times are GMT -7. The time now is 01:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
