Originally posted by mee Are you still upstairs? :cP
LOL - I am. But tonight was chaotic. Sorry. I'll try to grab it and measure it but things are crazy tonight. Youngest child spilled pounds of sugar in the kitchen while we were out... you know how much fun that is. Mopping time.
---------- Post added 09-04-15 at 10:19 PM ----------
Wow - that's significantly bigger.
Here are the measurements. From the base to the LOWEST VALLEY on the tulip: 50-51mm
From the base to the LOWEST PEAK on the tulip: 73mm
From the base to the HIGHEST PEAK on the tulip: 90mm
Inside Width at the LOWEST VALLEY: 88mm
Inside Width at the HIGHEST PEAK: 89mm
Being wider I guess that helps but wow - that's a much longer hood.
I think I would create a construction paper replica of that diameter and mount it on a posterboard ring to allow me to see the max length without vignetting and then I'd wrap a paper template around that hood and cut the excess off.
