09-14-2015, 12:37 PM   #16
UncleVanya's Avatar
QuoteOriginally posted by Kaiowas Quote
A bit offtopic, but as far as i know the Camera exposures a second time in Bulb Mode with closed shutter to have a "Noise Negative" and then to distract it from the real image. So i guess there is still a big plus for using Bulb Mode instead of normal Shutter Speed even if i Bulb less than 30 seconds?
Slow shutter speed NR works in all modes as far as I know. I think it triggers on anything over 1 second but I can't recall the exact details. I do know for sure Bulb mode is not required.
09-14-2015, 01:19 PM   #17
TER-OR's Avatar
Thanks alot for all the replies! Indeed i didn't need more than 30 Seconds Exposure, because Stars started to draw lines. Simply used 2s Delay Mode.
Investigate the astrophotography threads here for strategies using or not using the dark frame subtraction. The star guys here are an active and helpful group, definitely not a den of villainy.
09-14-2015, 01:59 PM   #18
...A bit offtopic, but as far as i know the Camera exposures a second time in Bulb Mode with closed shutter to have a "Noise Negative" and then to distract it from the real image. So i guess there is still a big plus for using Bulb Mode instead of normal Shutter Speed even if i Bulb less than 30 seconds?
There's a menu setting to control whether or not the dark frame is taken. If you only plan to take a few random sky shots, I suggest using it for less noise. Turn it off when you are taking many photos, especially for a time lapse or for stacking later.
09-14-2015, 04:17 PM   #19
Oldbayrunner's Avatar
The OP mentioned that their phone loans the ir port needed.
Loans the ir port???? Perhaps you mean it lacks it.
09-14-2015, 04:21 PM   #20
UncleVanya's Avatar
QuoteOriginally posted by Oldbayrunner Quote
Whoops. Yes indeed.
09-14-2015, 06:12 PM   #21
Otis Memorial Pentaxian
The background subtract can be set three ways: 1) Auto (default), 2) On always, and 3)Off. When set to Auto, it may be invoked in any mode where the combination of ISO and shutter time is likely to result in excess noise. I was able to get it to kick in when at 10 seconds and ISO 3200 on the K-3 in multiple modes. Likewise, short exposures in Bulb will not invoke the background subtract when set to Auto.
10-10-2015, 08:03 PM   #22
eye
Hi everyone,
currently i am on holidays in the middle of nowhere in Poland, and the Starlight is just beatiful. Unfortunately i dont have any kind of Remote control for long Bulb exposures. So i wanted to know if there is any way to cheese a remote for my Pentax k-5, any kind of trick?
I tried a Samsung App, but it needed some kind of infrared Extra to work. Second thought was to try out a TV-Controller, maybe it's infrared could trigger my cam, but no success. Lastly i got a Mecablitz 58-2 Flash but there i also couldn't find a way to trigger my camera.
If anyone has another idea i would be thankful.
best,
Kaiowas
If you cannot do what you want to with bulb mode, an intervalometer may help. They can be wired, or not. If you want to be able to trigger the camera (or change your programed set of pics) at a big distance, you want one that uses wifi to communicate (not IR or bluetooth).
pentax, tripod
Any way to get K-5 serial number besides on the body? (stolen) SenorBeef Pentax DSLR Discussion 14 09-11-2015 05:45 PM
Any other K-3 owners feel like a tri-pod is the only way to get crisp photos? HomeMadeSin Pentax K-3 & K-3 II 70 12-13-2014 11:20 AM
Wanted to know if their is any way to get back the deleted photos? caedmon General Talk 4 01-25-2012 08:50 AM
Any way to get a lower ISO than 400? randesigns Pentax K-r 6 07-07-2011 12:24 PM
Any way to get to Shutter Speed of 1/60.000 throndor Pentax DSLR Discussion 6 09-18-2008 02:57 AM
All times are GMT -7. The time now is 11:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
