09-13-2015, 12:18 PM   #1
Any way to get my Pentax remote-controlled?
Hi everyone,
currently i am on holidays in the middle of nowhere in Poland, and the Starlight is just beatiful. Unfortunately i dont have any kind of Remote control for long Bulb exposures. So i wanted to know if there is any way to cheese a remote for my Pentax k-5, any kind of trick?
I tried a Samsung App, but it needed some kind of infrared Extra to work. Second thought was to try out a TV-Controller, maybe it's infrared could trigger my cam, but no success. Lastly i got a Mecablitz 58-2 Flash but there i also couldn't find a way to trigger my camera.
If anyone has another idea i would be thankful.
best,
Kaiowas
09-13-2015, 12:32 PM   #2
CDW
I believe this page may be helpful:
https://www.pentaxuser.com/forum/topic/bulb-mode-on-a-k5-38488
09-13-2015, 12:39 PM   #3
Some TV remotes do work, you just have to find the right code (a universal remote where you can program it for any TV is helpful) and the right button. And then you'd set the camera for 1st press down and 2nd press up for bulb mode. (You can't "hold" a button with IR remote.)
09-13-2015, 01:09 PM   #4
QuoteOriginally posted by Kaiowas Quote
Hi everyone,
best,
Kaiowas
What phone do you have? Some have ir, some don't.
There are inexpensive ir triggers available, probably at a camera shop.
09-13-2015, 01:18 PM   #5
UncleVanya's Avatar
Self timer is insufficient?
Wired cable remotes use a headphone jack plug. My guess is you could rig one with a small switch and headphone cable.
09-13-2015, 01:28 PM   #6
Otis Memorial Pentaxian
"DSLR Remote" App for Android...uses the IR blaster on most recent Android phones. Free.
09-13-2015, 01:31 PM   #7
...If anyone has another idea i would be thankful...
Use manual mode. You'll be limited to 30 seconds but anything much longer than that is going to cause the stars to trail, anyway. Set the shutter mode to 2-second delay to prevent vibrations from pressing the button.
If there's a local store selling Canon but not Pentax supplies, note that some Canon wired shutter release cables fit Pentax. Canon uses 2 different jack types and 1 of those is the same as Pentax.
09-13-2015, 01:38 PM   #8
Oldbayrunner's Avatar
+1 for DSLR remote. Works with my Android phone and k5lls.
09-13-2015, 02:04 PM - 1 Like   #9
Use a hat of something to cover the lens without touching it. Cover the lens, trip the shutter manually, move the hat - letting the light in. Then reverse it when you want to end the exposure - cover the lens with the hat, and trip the shutter again to close the shutter. There is an option in one of the menus to allow you to push the shutter once to open it and again to close it. Pull the camera manual on line and search for the option.
09-13-2015, 03:26 PM   #10
QuoteOriginally posted by interested_observer Quote
Duh. You win. The rest of us blinded by technology...
09-13-2015, 03:43 PM   #11
Sandy Hancock's Avatar
QuoteOriginally posted by interested_observer:
On my K-3 and K-S2, the 7th option in the C menu is "Bulb mode options". Set that to option 2.
Then use either a hat as suggested above, or the Pentax Infra-red remote control. The latter is inexpensive, weather sealed and works well. But so is the hat I guess
09-13-2015, 06:00 PM   #12
UncleVanya's Avatar
QuoteOriginally posted by Oldbayrunner Quote
The OP mentioned that their phone loans the ir port needed.
09-13-2015, 07:07 PM   #13
narual's Avatar
If it helps -- Pentax uses the same wired remotes that Canon does.
Or you can just program it in interval mode. Have it take a 30 second shot every 45 seconds or something.
09-13-2015, 07:15 PM   #14
j0n4hpk's Avatar
Try the Jue Ying Remote Control RC-4, mentioned somewhere in this website as a remote trigger. If you have other makers DSLRs or even some film SLR cameras, you will need only this one.
09-14-2015, 12:27 PM   #15
Thanks alot for all the replies! Indeed i didn't need more than 30 Seconds Exposure, because Stars started to draw lines. Simply used 2s Delay Mode.
A bit offtopic, but as far as i know the Camera exposures a second time in Bulb Mode with closed shutter to have a "Noise Negative" and then to distract it from the real image. So i guess there is still a big plus for using Bulb Mode instead of normal Shutter Speed even if i Bulb less than 30 seconds?
pentax, tripod
Any way to get K-5 serial number besides on the body? (stolen) SenorBeef Pentax DSLR Discussion 14 09-11-2015 05:45 PM
Any other K-3 owners feel like a tri-pod is the only way to get crisp photos? HomeMadeSin Pentax K-3 & K-3 II 70 12-13-2014 11:20 AM
Wanted to know if their is any way to get back the deleted photos? caedmon General Talk 4 01-25-2012 08:50 AM
Any way to get a lower ISO than 400? randesigns Pentax K-r 6 07-07-2011 12:24 PM
Any way to get to Shutter Speed of 1/60.000 throndor Pentax DSLR Discussion 6 09-18-2008 02:57 AM
All times are GMT -7. The time now is 03:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
