10-18-2015, 12:13 PM   #1
csa's Avatar
Card Readers
I need a new card reader for use with my K3. Would these cover what I need?
"Supports SDHC UHS-I, SDXC UHS-I, UDMA7 CF and MSXC"
Thanks!
10-18-2015, 12:53 PM   #2
this is the one I use.
Lexar Professional Workflow SR2 SDHC / SDXC UHS-II LRWSR2RBNA
It is fast, reliable, and has a light that tells you when the card is active. The light goes off, when it is safe to remove the card. it only has one slot, for SD cards, but I only use SD cards so it is not a problem. it has reliably read every manufacturer's card that I have put in it, without any problems.
10-18-2015, 12:57 PM   #3
csa
csa's Avatar
It doesn't say if this one is also 2.0 compatible. This is important, as my computer only has 2.0.
10-18-2015, 01:12 PM   #4
csa
csa's Avatar
Found this one that is either 3.0 backward compatible to 2.0:
Kingston USB 3.0 High-Speed Media Reader FCR-HS4 B&H Photo Video
Looks like it will cover whatever SD's I buy.
Opinions on this one?
10-18-2015, 01:16 PM   #5
QuoteOriginally posted by csa Quote
I have used it on both USB 2.0 and USB 3.0, Without issue.
10-18-2015, 01:38 PM   #6
csa
csa's Avatar
Thanks for that information!
10-18-2015, 02:43 PM   #7
Anything that's USB3 compatible should also work at a slower speed with USB2 ports. But if you don't have USB3 on your computer, you may as well just use a USB2 cord to connect your K-3, if you have one lying around.
10-18-2015, 03:23 PM   #8
csa
csa's Avatar
Thanks for that information Adam!
10-22-2015, 03:43 PM   #9
12345's Avatar
I paid less than $10 for my USB 3.0 SD card reader. (backwards compatible with USB 2.0) I got it from Amazon, and it works great! It has a status light, and seems to be decently fast. However, I got a different computer which had a built in card reader, so I don't use it any more. I do believe that the built in reader is a little bit faster though, especially since I don't have any USB 3.0 ports.
---------- Post added Oct 22nd, 2015 at 18:45 ----------
Sorry, forgot the link! Here it is: http://www.amazon.com/gp/product/B009D79VH4
10-23-2015, 09:20 PM   #10
pacerr's Avatar
If you have any use for the Micro-SD cards get one that supports both SD and micro-SD.
Aside from using micro's with tablets/phones, you can stick a micro-SD card in fthe device while reading the SD's and use it as a separate memory buffer. (The reader will show up as TWO memory slots.) Makes it convenient to actually do a card back-up to a separate library.
Here' one from Kingston for example:
Kingston MobileLite G4 USB 3.0 Card Reader Review - Legit ReviewsKingston MobileLite G4 UHS-II SD Card Reader
TigerDirect.com is a good source.
10-26-2015, 08:43 PM   #11
csa
csa's Avatar
Thanks 12345, that's a great deal!
Pacerr; I really have no need for Micro-SD's; but I agree TigerDirect.com is a good source for a lot of things!
10-27-2015, 06:44 PM   #12
12345's Avatar
You're very welcome, I'm glad you like it!
card, reader, sd card, tripod, uhs-i, usb
multi card readers csa Pentax Camera and Field Accessories 13 03-16-2015 12:54 PM
Are all card readers crap? dadipentak Pentax Camera and Field Accessories 25 11-16-2011 10:13 PM
memory card readers; which one? rdrum76 Pentax Camera and Field Accessories 9 02-02-2009 10:25 PM
Card readers trishytee General Talk 2 01-08-2009 08:12 PM
are there any fast card readers that support SDHC? shadowrulz3164 General Talk 11 03-01-2007 09:50 PM
All times are GMT -7. The time now is 04:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
