Originally posted by FantasticMrFox I have one. I know that front elements are ridiculously strong and scratch resistant, but I still use the little brush to remove dust etc. first before I wipe it with a microfibre cloth.
That is the proper use of the lenspen.
For those curious:
1) use the brush to gently whisk away any 'large' debris.
2) use the round, carbon tip to clean up any smudges.
In that order.
You don't need to use the carbon side unless you have smudges or other forms of speckles/fingerprints.. because that is why they specifically use carbon (pull up grease).
Otherwise, gently use the brush side for dust and the like.
I've been using them for over 5 years now.. never a scratch.
That said if you use the carbon side and rub out sand or grit on the front of you lens (instead of using the brush) you are asking for trouble. Then again, you are asking for trouble doing this if with a lenspen, microfiber cloth, shirt sleeve, etc. So it isn't a lenspen issue specifically.
