11-13-2015, 07:55 AM   #16
It sounds like a balance issue and changing heads won't fix that. You need a lens collar, or an extended plate so you can shift the camera further back on the ball head.
11-13-2015, 08:12 AM   #17
BigMackCam's Avatar
QuoteOriginally posted by DeadJohn Quote
I think you're right about the balance issue. I had previously searched online for something like the extension plate you mention, but couldn't find anything (maybe I used the wrong description in my search). I guess I could have something made. I can't use lens collars because, on the small number of zooms I have, there's really nowhere a collar would fit...
---------- Post added 11-13-2015 at 03:14 PM ----------
QuoteOriginally posted by interested_observer Quote
... I found one on Craigslist... for $75.
Wow. That's a deal I'd have jumped on, too. Nice catch I wonder if he's depreciated the Arca Swiss Cube yet?
11-13-2015, 02:35 PM   #18
Oldbayrunner's Avatar
That's what the Manfrotto 293 allows one to do, change the lens to camera balance ratio by utilizing different attachment points. Utilizing an Acratech style head and plate one could fine tune the balance further.
11-13-2015, 02:46 PM   #19
BigMackCam's Avatar
QuoteOriginally posted by Oldbayrunner Quote
That's what the Manfrotto 293 allows one to do, change the lens to camera balance ratio by utilizing different attachment points. Utilizing an Architect style head and plate one could fine tune the balance further.
Aha! Just looked this up after I read your post.... this looks excellent! Might be a stretch to use it with my Q7 plus K teles, but for the K5 & K3 it looks perfect. Thanks for the heads-up!
11-18-2015, 12:19 PM   #20
I have a 410 year head and find that heavy loads can make it wiggle slightly. Bought it used from a wildlife photographer from Alaska. So it is a bit worn. Have you considered a gimbal type? I now use the Kenko KDS II which was modified to use arca clamp or the native vixen (telescope) clamp. It has quasi-gimbal design with gears that move similar to the 410. I have a review in the Accessories database. The moon pic is with a 6 lb. Telescope. Just a thought....
11-18-2015, 02:56 PM   #21
BigMackCam's Avatar
QuoteOriginally posted by goldenarrow Quote
That Kenko KDS II is a monster It looks nice, but probably overkill for what I want or need (but thanks - I appreciate the heads-up). If I can get the camera back from the fulcrum point of the mount, I should be ok, I think... possibly even with the existing Giottos MH7001 head I already have... I'm thinking I may get a thick steel plate made for this purpose, as I can't find anyone actually selling such a thing
11-18-2015, 04:39 PM   #22
The Kenko is actually not too heavy, just a little awkward to carry. It is not as big as a Wimberley nor can it carry as much load. accessoryreviews/kenko-kds-mount-ii
But, I am reminded that I before that, I had used a Vixen/Berlebach clamp screwed to the RC4 manfrotto plate and used a manfrotto video plate into the vixen clamp. I could then use it to balance a heavy scope on either the manfrotto 410 gear head or the 498 ball head. Annoying and heavy to carry but it was balanced fairly well. I was using a 5 pound telescope at the time and was OK to work with until I found lighter gear to adapt.
300mm, advice for consumer, amount, balance, balance issue, ball, ball head, choice, collar, head, issue, lens, lenses, manfrotto, plate, tripod, tripod head advice, velbon
Third party focusing screens for K5 & K3? BigMackCam Pentax DSLR Discussion 29 07-20-2017 12:59 AM
Single row Tripod/Ball head and accessory set up advice mikeodial Pentax Camera and Field Accessories 5 11-28-2014 01:09 PM
Oben CT-3561 5-section travel carbon fiber tripod & head: $200 (B&H) Doundounba Pentax Price Watch 11 11-19-2014 05:33 PM
I've waited too long for a good tripod & head! stormtech Pentax Camera and Field Accessories 8 06-16-2011 01:12 PM
Tripod/head setup - advice bpv_UW Pentax Camera and Field Accessories 10 02-12-2011 04:07 PM
All times are GMT -7. The time now is 12:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
