Originally posted by Imp What's wrong with it? Legitimately curious, because i've been fine with the strap that came with my k-30
I use a Blackrapid sling strap and would never go back to a neckstrap as the weight is on one's shoulder, rather than on the neck, and I only attach the strap when I need it.
The latter aspect takes away the security risk every permanently attached strap represents. One can involuntarily catch the strap, pulling the camera from a table, for instance, or have strap be caught somewhere when picking up the camera, causing one to lose grip on the camera.
Outside the security concern it is also much nicer to handle purely the camera without the strap drama attached, when no strap is needed. Try it sometime!
There is also the stupid "camera dangling in front of you" aspect of neck straps that others already mentioned, but even though carrying the camera on the side is much nicer, the above reasons even trump that aspect, AFAIC.
