I've been wanting to devise a better system for using my long lenses at my "bad weather hide" i.e., my livingroom window. The beanbag setup I use for the Sigma 150-500 isn't useful for the DA 560 because it's more unwieldy. I work on a narrow bookcase and my tripods won't get the lens close enough to the window. So, into the garage I went, sifted through my scrap wood stash, bought $1.50 worth of stainless bolt and washer, and finally got what I wanted.
The end result is really sturdy, mobile, and can take any tripod head. I made the dimensions to match what I needed for my bookcase, but you could change them up as required. I wanted something specific so I could slide the lens right up to the window. That avoids reflection from the glass.
This would make a great ground pod, too. Maybe I'll make another one and get fancy with rounded feet and "All-weather" materials. This time around, I didn't do any fancy finishing because I wanted it *now*. It took me about an hour.
Materials:
3/4 inch board cut to 15 x 18 in
2x4 cut into 3 pieces
2 1/2 x 3/8 in stainless bolt
7/8 in washer
To begin, cut the boards to length
Screw them into place. I made the middle one shorter for a handhold
Closeup of the bolt and washer. You want it deeper than flush with the bottom.
Here's the top side
Screwed on the tripod head
Ready for critters
This is my feeder setup outside. I was trying to lure a flicker with the insect suet and, just as two (!) of them flew up, a hawk descended on the bird party and scooped up a tiny little bird. I felt bad for luring the poor thing to its death
The flickers disappeared for the rest of the day.
Here are a few shots straight from the JPEG card, uploaded to my Ipad. That's a warning not to be looking for sharpness. The last one is nearly in the dark, at ISO 12800, while I was writing this post. A horde of little birds descended on the suet log while I snapped away and they flew around like crazy for about a minute. Then, poof! They were gone.
Tied some berries and branches to the pole
This little fella kept trying to climb the suet pole. No luck!
The horde:
It was a great day. I'm looking forward to getting those flickers. And maybe that hawk, too.
Reason: Resized photos
