01-20-2016, 07:53 AM   #1
bellows and aperture actuation
Hope it's the right section.
I've recently bought a cheap bpm bellows (full manual) with pentax k adapter, it works great but it is a little annoying to fiddle with the aperture ring every time i want to check or change the focus. So i was wondering if there is some kind of adapter i could use to activate the aperture lever on the lens, to allow something like a pre select lens. I know there is the pentax bellow but i can not afford it right now. Do you guys know some alternative?
01-20-2016, 08:45 AM   #2
If your bellows isn't built for it, then AFAIK you're stuck with stop-down metering. Start saving your pennies.
01-20-2016, 09:37 AM   #3
Thats a shame, i'm not really interested in metering, just a way to open wide and then return to working aperture to ease focus.
01-20-2016, 09:44 AM   #4
UncleVanya's Avatar
So there are a couple of options. The genuine Pentax auto bellows came with a cable release that would do that for you. The camera side release would only work with a physical bracket to push the button on the DSLR - but you could use it to actuate the lens only and then trip the camera another way.
The novaflex system bellows are crazy expensive but offer electronic communication typically - although I haven't verified it works that way with Pentax. https://www.novoflex.com/en/products/macro-accessories/bellows-systems/adapters-for-castbal-ts/
An M42 lens with the Auto/Manual switch makes a nice quick to use option - auto while focusing, manual when shooting. It is a simple single slide switch vs. clicking off the aperture stops.
01-20-2016, 11:04 AM - 1 Like   #5
pacerr's Avatar
Or an older 'pre-set' lens with dual aperture rings.
Working with bellows is a deliberate enough process I've never considered a manual aperture a hindrance.
01-20-2016, 11:56 AM   #6
UncleVanya's Avatar
QuoteOriginally posted by pacerr Quote
I have typically used an M42 bellows so I haven't noticed either. I often use an enlarging lens on the end of it or an M42 lens. To be honestly mostly I use my dedicated macro lens or add on Raynox.
01-20-2016, 12:08 PM   #7
baro-nite's Avatar
If you're shooting digital and your camera has live view, there's another option.
There's also an older Novoflex bellows with a mechanical aperture linkage, but these seem to be uncommon.
01-20-2016, 02:40 PM   #8
Thanks for the replies guys. I'll probably set for now with what i have, can't afford much and i prefer to save for lenses. The bellow work well anyway for my needs, it's just that coming from the macro tubes with aperture lever i missed it a little.
adapter, aperture, lens, pentax, tripod
K-5 freezing each and every shutter actuation Clavius Pentax K-5 & K-5 II 5 02-09-2016 12:36 AM
Macro bellows macro large aperture - moss margriet Photo Critique 9 03-13-2012 10:09 AM
For Sale - Sold: Bellows Takumar 100mm/4 and Pentax Auto Bellows (Worldwide) lynch1234 Sold Items 18 11-16-2010 01:41 PM
For Sale - Sold: Bellows and 150mm bellows lens Peter Zack Sold Items 6 02-25-2010 05:04 PM
K-7 and bellows : aperture problem fs999 Pentax DSLR Discussion 4 01-07-2010 02:03 PM
All times are GMT -7. The time now is 11:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
