01-22-2016, 03:27 PM   #1
Is there any "ready" bag/case for Pentax K-r?
Hi,
I usually like to have/use a "ready" type case/bag for my cameras, and I just picked up a K-r, so I've been trying to find one for it. So far, no luck though.
I noticed that there are ready cases for the K30, e.g.:
http://www.amazon.com/MegaGear-Protective-Leather-Camera-18-135mm/dp/B00Y7Y6E8W
but not for the K-r.
I was looking at cameracomparison.com (I think) to compare the size/shape of the K30 vs. the K-r, and they looks about the same, so was wondering that K-30 case would work with the K-r? Or maybe someone knows of another one?
Thanks,
Jim
01-22-2016, 03:51 PM   #2
I don't use a 'ready-case' for my K-30, but this site may help you some:
It compares the K-r size to the K-30 size:
Compare camera dimensions side by side
Using the control box on the left, you can switch the view of the camera bodies to get different comparisons and dimensions. Maybe a little bit of help.
01-22-2016, 04:13 PM   #3
Since K-r is an older model, i don't think you'll find regarding current products, references to it in particular. You'll just have to find a case for a similar camera, like you did.
IF you want a leather case (like the one you linked for Ks-2 not K-30 btw) do a body comparison + take into account the lens (the case you put the link to is for the Ks-2 with the 18-135, a slightly larger lens than the 18-55 kit). This wouldn't be a problem though, the problem is when it's the other way around
Use this link for detailed info (camera dimensions including) on Pentax cameras
Or go with a streachable neoprene cover, similar in shape to the one you chose but clearly not as stylish
Good luck with the K-r! It's a good, trusty camera
01-22-2016, 04:45 PM   #4
QuoteOriginally posted by yucatanPentax Quote
I've been doing that but was hoping someone might actually have it.
01-23-2016, 06:08 AM   #5
I found one for a K-30:
http://www.amazon.com/gp/product/B014ITOQK8
using the comparison website, the K-30 looks similar size to the K-r. I think that there may be a fit problem with the top part where the viewfinder is, but worst case I can cut a hole in the top of the case if I have to.
---------- Post added 01-23-16 at 06:37 AM ----------
Pics of the bottoms - K-r vs. K-30:
K-r:
http://www.imaging-resource.com/PRODS/KR/ZURBATT.JPG
K-30:
http://www.steves-digicams.com/camera-reviews/Pentax%20K-30-bottom.jpg
They are definitely different, but hoping that the tripod mount hole is the same place!
01-29-2016, 03:40 PM   #6
Hi,
FYI, for the record, I just received this case from Amazon:
http://www.amazon.com/gp/product/B014ITOQK8?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01
and it actually fits the K-r "almost" perfectly. Actually, it is perfect, except the part for the lens is kind of long, like a long "snout". I guess it would be good if I had a long zoom lens, but with smaller lens, it is kind of wasted space.
The body fits perfectly, and the screw on the bottom matches up with the tripod mount on the bottom of the K-r.
01-29-2016, 03:53 PM   #7
csa
csa's Avatar
Great news, glad you found something and also that you shared it here for others!
bag/case for pentax, camera, hole, k-30, k-r, k30, pentax help, photography, tripod, troubleshooting
K3 II - is there a "little flash"? peterh337 Pentax K-3 & K-3 II 11 08-15-2015 06:58 AM
"Click" in between "C" and "MF" mode on focus selector? K-50 maxwolfie Pentax K-30 & K-50 3 01-29-2015 04:19 AM
Get ready for the PF "Limited" November Giveaway! Adam Pentax News and Rumors 6 11-18-2014 01:45 AM
Is there a "K" club? Douglas_of_Sweden Pentax SLR Lens Discussion 6 03-05-2009 10:08 PM
Is there "Shutter Releases Counter" for Pentax? D0ri Pentax DSLR Discussion 9 02-22-2009 03:11 PM
All times are GMT -7. The time now is 06:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
