02-03-2016, 01:11 PM   #16
Below are the paths to the rechargeable batteries, charger, and EU to US plug adapters, in that order.
Li ion Rechargeable 2032 Button Cells LR2032 | eBay
New Coin Button Cell Battery Travel Charger for LIR2032 2025 EU Plug AC100 250V | eBay
2pcs EU to US USA 110V Socket AC Power Plug Adapter Outlet Travel Converter | eBay
02-03-2016, 01:20 PM   #17
csa
csa's Avatar
Thanks for taking the time to assist! It's appreciated!
02-03-2016, 01:26 PM   #18
THoog's Avatar
QuoteOriginally posted by csa Quote
Good point! I believe the wireless port is probably the same on the K3 (front); I'll have to take a look. This may have me rethinking getting a wireless one!
The K-3 and the other "metal" bodies have both front-and-rear wireless sensors. The "plastic" bodies only have the front one.
02-03-2016, 01:30 PM   #19
csa
csa's Avatar
Thanks Todd; I had just looked at my K3, and did see that it had both front & back sensors.
02-03-2016, 01:35 PM   #20
Oldbayrunner's Avatar
Why bother buying those... This works great.... https://play.google.com/store/apps/details?id=de.dslrremote
02-03-2016, 02:03 PM - 1 Like   #21
You are welcome. Could you possibly tell me, when you use your Vello wired shutter release, do you have your camera drive mode set to ""Remote", or is that not required, which I am thinking may be a possibility since the "wired" is not wireless "remote"? I am almost ready to buy it and wanted to find out if you possibly knew.
02-03-2016, 03:18 PM   #22
I just wanted to thank you all for your input.
I went ahead and ordered the Vello RS-C1II Wired Remote Switch for Select Cameras RS-C1II B&H to use with my K-3II and K-5IIS.
I appreciate the help.
02-03-2016, 04:23 PM   #23
csa
csa's Avatar
QuoteOriginally posted by C_Jones Quote
Sorry for the delay. No, I don't change the drive mode to Remote. It works with my regular settings.
02-03-2016, 04:24 PM   #24
csa
csa's Avatar
I think you will be very pleased with it! Be sure to let us know how you like it!
02-03-2016, 05:00 PM   #25
Ex Finn.'s Avatar
QuoteOriginally posted by Oldbayrunner Quote
Yes it does work great. I do prefer a wired remote for long sessions while using a telescope.
02-03-2016, 05:06 PM   #26
WPRESTO's Avatar
I have several Vello wired remotes and two Vello wireless remotes - they all work with my K3 and all that I've tried work on my K5 and K20. The Pentax plug is the same as that used on many (all??) Canon DSLRs
02-03-2016, 05:55 PM   #27
csa
csa's Avatar
Because not everyone has a smartphone, including me.
02-03-2016, 06:26 PM   #28
What do you use, tin cans on a string???😂
02-03-2016, 06:38 PM   #29
ramseybuckeye's Avatar
QuoteOriginally posted by dlh Quote
The wireless remote port on my K-50 is in the front of the camera, so it's really only useful if I want to take pictures in which I'm in the scene. The wired remote is a lot more useful, because I can use it to take a picture when I want absolutely no shaking, e.g., w/bulb or slow shutter speeds.
All you have to do is reach towards the front of the camera, you don't have to be in front of it.
02-03-2016, 06:41 PM   #30
Brooke Meyer
Guest
I have a K-3II and a K-5IIS. I ordered a Foto&Tech Wired Remote Shutter Release Control CS-205 Replacement for PENTAX 645Z, 645D, K3, K5, K5 II, K30, K50, K500, K7, K110D, K100D, K100D Super, K200D, K10D, K20D and it did not work with either camera. I do not know if I was sent the wrong model, but it looked exactly like what was in the picture of it on the web. I sent it back today, and was notified that my refund was approved (Amazon).
So, I have been looking at the Vello RS-C1II Wired Remote Switch for Select Cameras RS-C1II B&H. Does anyone have any experience with this product? B and H seems like they know what they are doing, and I want something that works.
Both of these work on K5IIs bodies. The wireless version works around corners and a good distance away. The wired version uses no batteries.
Vello FreeWave Wireless Remote Shutter Release RW-C1 B&H Photo
batteries, camera, cameras, delay, feedback, front, input, k100d, k5, k5iis, lobster, pentax, plan, pm, post, reason, release, remotes, shutter, sunday morning, thanks, tripod, vello, version, weather
Wired remote shutter release? clyde Pentax K-5 & K-5 II 12 12-20-2015 06:54 PM
remote shutter release and bracketing sunrepairer Pentax K-30 & K-50 3 06-02-2015 07:10 PM
Remote Shutter Release for 645Z uintaangler Pentax Medium Format 3 03-05-2015 03:27 PM
Very Capable Remote Shutter Release RockvilleBob Pentax DSLR Discussion 2 08-19-2014 08:32 AM
Wired shutter release for K5 WizBird Pentax K-5 & K-5 II 5 01-10-2013 05:52 PM
All times are GMT -7. The time now is 11:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
