Originally posted by ChipB Borno, looks good - nice bit of "home engineering"!!
But, I have a question about gimbal heads - I haven't run into one before and wonder what the advantages are over a ball head? Thanks.
A ballhead is generally regarded as sturdier for fixed shots and more general-purpose.
Gimbal heads are pretty much specifically for users of long lenses who need to pan frequently (due to moving subjects - birds, sports, aircraft). They're slightly less sturdy for "still" shots, but they are a LOT easier to move than a ballhead.
The idea is that with a ballhead, the center of gravity of the lens + camera is above the pivot point of the head. Thus if the ballhead is loosened the lens will tend to flop around and the photographer will have to fight it. Also a ballhead allows rotational movement around the lens axis.
With a properly adjusted gimbal head, the lens+camera combination's center of gravity is right at (or sometimes slightly below) the pivot point of the head. As a result the lens will tend to either not move or possibly have a tendency to return to horizontal. This way it can be panned easily left/right/up/down (but kept level, a gimbal head does not allow rotation around the lens axis) with little effort.
