I have four -for some of you maybe silly
- questions about the external Flash AF-540 FGZ on the K20d.
Does the selected flash mode (Auto discharge, Auto flash+ Redeye reduct, Flash On+ Red-eye, Slow-speed sync, Slow-speed sync+ Red-eye, Trailing curtain sync slow and normal) also affect the external flash AF-540 FGZ or only the built-in flash?
Given: I want the following settings and flash mode:
Slow Speed Sync and on the K20d Tv OR P with Tv.
Question: Do I have to set the K20d flash mode to SLOW or does this the K20d automatically when the Shutter Priority is slower than 1/150 ?
High-Speed Sync and on the K20d Tv OR P with Tv.
Question: Do I have to set the K20d flash mode to “Flash On“ only and on the AF-540 FGZ to HS?
Confusion: On page 145 in the K20d Operating Manual says: “High-speed flash sync is only available when the shutter speed is faster than 1/180 sec.“ but in the AF-540 FGZ Manual on page 76 (High-Speed Sync Mode Photography) it says: “ Set the camera using the Av or Tv dial so than the shutter speed is faster than 1/150.
What is right?
Question to the Leading and Trailing curtain sync mode:
Do I have to set this on the K20d AND on the AF-540 FGZ or on the AF-540 FGZ only?
When only on the AF-540 FGZ then “Flash Only” on the K20d?
For infos a warm thanks in advance.
Fredlewin
