Getting more and more into long exposure photography with ND filters, and occasionally shooting the night sky in intervals for later stacking, I am looking to get myself an external intervalometer. The two main reasons are that the K3 will not allow me to set shutter speeds above 30 sec. unless I use Bulb, which requires me to physically keep the shutter pressed and manually time the exposure via my watch or phone, and the fact that when I shoot in interval mode it only engages the mirror lockup for the very first picture, and all subsequent ones are taken without, which is pretty detrimental to getting sharp, circular stars.
So now I am looking at an external cable intervalometer that is relatively affordable (up to €35/£25). Amazon shows a range of options that often look almost identical but come at different price points, such as
this 'Neewer' one and
this no-name one, which are both described as working with Pentax, look virtually identical and seem to have the same feature set, but at vastly different price points (£21 vs. £13).
Does anyone know what the quality of these is like? I know I cannot expect K3 level build quality from something so affordable, but I would be rather disappointed if that thing falls apart after three uses. Alternatively, are there any other good ones out there that fulfil my needs at the given budget?
