I haven't found a good solution to carrying square plastic filters in the field, so I'm wondering what everyone else does.
Realistically everyone has to put away filters that are covered with salt, mud, etc. before they can be cleaned, so the problem is that even a soft case/pouch or anything the filter surface can touch will scratch them. Sliding a dirty filter in or out of any kind of sleeve will pretty much seal its fate. That's not so much a problem with modern glass filters, particular with the very latest coatings that can really take a beating, but few of us have such square filters. And the glass filters get a bit of a break from the frame, which removes at least some of the glass contact surface. Generally putting square filter into the old Cokin clamshell cases works ok since at least that prevents rubbing, and it's possible to improve them slightly by adding some strips to the clear side edges to prevent the main body of the filter from contacting the clear plastic. But the clamshell case is awkward to handle - you can't just shove a filter into it with one hand and that's really what's needed.
I guess something like I envision could be made from old Cokin clamshell boxes by cutting out the opening end, although cutting the boxes without cracking them seems to be tricky, and you still have to add something to the clear side to prevent the filter from touching, and that makes the slot pretty narrow. But eventually the world will run out of old Cokin plastic boxes, so still not an ideal solution.
