04-17-2016, 05:02 AM   #1
Camouflage for 600mm f5.6A lens
Hi All.
I have a Pentax 600mm f5.6 A lens, which is, of course, a white lens that is in need of some camouflage for the type of nature photography I like to do. When I was young I used camouflage tape on an old 300mm lens and it ended up looking pretty awful as the glue from the tape ultimately wouldn't come off. I suppose I will need neoprene but when I went to a hunting store, I didn't see anything there that I would really want to use. Any suggestions on product or source shops that work well and that won't damage the lens?
Doug
04-17-2016, 05:23 AM   #2
Not a Number's Avatar
LensCoat uses neoprene collars and sleeves. They don't have your lens listed but they say to contact them if your lens is not listed.
Pentax Covers - LensCoat
There are other options like a cloth/net sleeves or capes::
http://www.carolinawildphoto.com/primecover.htm
04-17-2016, 05:24 AM   #3
p38arover's Avatar
3M Automotive Wrap Film in Camouflage?
04-17-2016, 05:56 AM   #4
On eBay there are plenty of rain covers in various camouflage patterns that should fit and are very cheap ($20-$30). If the measurements of the A 600 f5.6 near-enough resembles popular lenses like the Tamron or Sigma 150-600's, you will have lots of designs and patterns to choose from.
04-17-2016, 11:56 AM   #5
My suggestion would be to go to a fabric store and get some burlap, Velcro, and some fabric glue.
Cut the burlap long enough so that it will overlap itself by about an inch. Use the fabric glue to glue the Velcro to the burlap so that when you wrap the burlap around the lens, the Velcro will stick to itself. You might want to make two of these depending on the weave of the burlap.
While at the fabric store, see if they have some fabric that is a camouflage pattern that you can use instead of the burlap.
04-17-2016, 01:23 PM   #6
QuoteOriginally posted by bigdavephoto Quote
I think that basic idea is ok, but avoid fabric that will tend to throw off tiny fibers that are going to end up inside the lens (unless you treat the fabric with something that will hold it together). Burlap might fall into that category. Also some fabrics will hold moisture. Seems like neoprene is the way to go, one way or another. It has all the right properties...
04-17-2016, 02:57 PM   #7
KiloHotelphoto's Avatar
I bought a yard of Woodland MARPAT on Amazon for $12 and had my mom make up a cover for my DA560. I wasn't looking for anything that would offer any protection from banging the lens around like the LensCoats just wanted to be able to cover up the bright white. Just got a couple of draw strings for the ends and some Velcro for the bottom and it works great. Easy to put on and take off for when I'm in the snow and want the white.
At work now or I would post a picture of it. Took my mom about 20 minutes to sew it all up, if you can't or don't have anyone that can do it a lot of dry cleaning shops offer alterations and they could do it pretty cheap.
04-17-2016, 05:05 PM   #8
QuoteOriginally posted by stemked Quote
Hi All.
Doug
http://www.amazon.com/Voodoo-Tactical-Mens-Military-Sniper/dp/B00B8BNY7Q
this is the easiest option
just drape over you and/or your lens
04-18-2016, 06:21 AM - 1 Like   #9
pete-tarmigan's Avatar
Hi All.
Doug
I have the same lens. I put Camo Form (made by mcnett.com) on the straight part of the lens that is just forward of the focus ring. I also put it on the hood. Camo Form is self-adhering bandage material that doesn't have any sticky adhesive. To cover the part where the lens flares outward, and to cover the area uncovered when the built-in lens hood is extended, I use "Lens Zoom Range Cover" ("zoom sleeve") made by wildlifewatchingsupplies.co.uk. They custom-made one for me (for a very reasonable price) by using a wider piece of material than they use in their standard zoom sleeve. When I extend the lens hood, the forward end of the zoom sleeve is pulled along for the ride. The ring with tripod foot is currently uncovered. The only option for that area seems to be an adhesive tape.
-Anthony Lang
04-18-2016, 07:45 PM   #10
The Camo Form by Mcnett is nice, I used the snow camo on my tripod this winter worked great.
04-23-2016, 08:19 AM   #11
csa
csa's Avatar
QuoteOriginally posted by KiloHotelphoto Quote
That definitely looks interesting. I want something for my 55-300, and LensCoat does not make one.
04-23-2016, 08:49 AM   #12
I just ordered two rolls from amazon.
I was looking at lens coat, but didn't want to spend 100 per lens. I have 3 lenses to cover.
For $40 it's worth a try.
05-29-2016, 12:45 AM   #13
Thank you for all your help.
05-30-2016, 01:14 PM   #14
I use this: http://www.amazon.com/Protective-Camouflage-Camo-Fabric-Rolls/dp/B00TOLW1NA?...rch_detailpage
Basically self cling camo tape, like they use on you in the hospital (in white though...). I actually saw it at my vet. No glue, so leaves no residue, and reusable. And about $5.
600mm, camouflage, camouflage for 600mm, k-mount, lens, pentax lens, slr lens, tape
FA* 250-600mm F5.6 Lens Coat/Cover pop4 Pentax SLR Lens Discussion 8 10-29-2019 04:08 AM
150-600mm F5-6.3 DG OS HSM | S for Pentax bwickett Pentax SLR Lens Discussion 32 12-30-2015 06:15 PM
Pentax-A* 600mm/f5.6 ED-IF Lens on eBay Weevil Pentax Price Watch 4 08-11-2013 12:09 PM
Looking for Pentax Lens Manuals for FA* 80-200 f2.8 and A* 645 600mm f5.6 seventhdr Pentax SLR Lens Discussion 5 11-16-2012 03:41 PM
All times are GMT -7. The time now is 06:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
