05-05-2016, 05:45 AM   #1
TER-OR's Avatar
Opinions from you dual-wielders.
Hi everyone.
I'm thinking of lugging two cameras in the field this year when doing my insect survey work. Often I see interesting birds or other critters and am limited to my 100mm macro. If I bring the K5 I can mount my 55-300 (or the DA300 if I buy that) and get a different set of pictures. Plus, maybe use it for dragonflies etc. which don't let me get close enough.
For those who do this already, what do you use? I have a Black Rapid Curve which is nice. They have a couple options for two-camera setups. I like the thought of the single sling Yeti, but the Double seems another good option.
I'm just interested to hear your experiences in the field. Does the Double get hot? It's more surface area. Is the weight of two DSLRs a bit much for the Yeti, making it uncomfortable?
05-05-2016, 05:50 AM   #2
Otis Memorial Pentaxian
clackers's Avatar
I use two slings.
05-05-2016, 06:06 AM   #3
bobell69's Avatar
I use the Cotton Carrier system. Allows me to carry two cameras while at the same time freeing my hands for hiking and climbing. Just came back from hiking in Zion and Arches National Parks and I wore the Cotton Carrier every day.
05-05-2016, 07:20 AM - 1 Like   #4
Na Horuk's Avatar
QuoteOriginally posted by TER-OR Quote
Here's what you need. You need to publish one photo in a major publication, and then act really arrogant. Then hang out around photography colleges, and these young people will flock to you. Once you pick one, you can call them an "assistant" and they will lug around all your gear for you. Make sure you always tell them what a good opportunity this is for them, and how this will help them with their eventual career lol
At least, that's how all the pros I know do it.
Edit: This post might have been a bit too dark. Sorry guys, didn't mean to insult anyone here Just a story about some people I have met not long ago
05-05-2016, 07:22 AM   #5
QuoteOriginally posted by bobell69 Quote
How do you carry the 2nd camera? Do you just put the 2nd holster on the vest's belt, do you use the Endeavour belt, or some other system?
I got a Cotton Carrier about a year ago and I only got around to using it a few weeks ago. Earlier, I had tried two slings but found that the cameras moved too much and there was too much risk of smacking one against something. I spend a lot of time standing, crouching and twisting - and moving fairly quickly - because I'm photographing animals. I liked the way the Cotton Carrier vest kept my camera attached to my body - much less risk of smacking it into something. But I've only tried it so far with a single body.
I'm planning to take it on our upcoming trip to the Galapagos Islands. And I'm trying to figure out the best way to carry the 2nd camera.
Which lenses do you use on the two bodies?
And you might find this thread helpful:
https://www.pentaxforums.com/forums/173-general-photography/281639-do-you-eve...wo-bodies.html
05-05-2016, 07:32 AM   #6
bobell69's Avatar
I use the side holster along with the chest harness as shown in this image 2 Camera Carrier Vest System On my recent trip, I took along my K3II and my K5. I had the K5 mounted with a DA* 50-135 and I used the 15 and 21 ltds on the K3II. From time to time when it was raining, I traded out the ltds for my 18-135 because I needed the weather sealing for my wide angle shots. Depending on my activity, I moved the cameras around, sometimes having the K3II on the side holster and more often than not on the chest harness. Either way, both cameras are comfortable and easy to access in a hurry. I found that with the system that I was using, even in warm weather the cameras didn't feel cumbersome, in the way or uncomfortable. Its a great system for balancing the weight for two cameras. Here is a link https://www.flickr.com/photos/roshin_photography/26227645244/in/dateposted/ to a shot of me wearing the carrier. My wife took the image with the K3Ii and I have the the K5 with the 50-135 in my hands.
05-05-2016, 08:32 AM   #7
Thanks! I am a little worried about heat and weight, so this is reassuring.
I also need to carry a small quantity of supplies for each excursion with me, so I'm planning to wear a small runners' backpack as well.
Maya 5 - Gregory Mountain Products
It has a couple of small pockets on each side of the hipbelt that are big enough to carry some essential bits and bobs, like a rocket blower, lens wipes, spare battery, etc.
05-05-2016, 08:47 AM   #8
pacerr's Avatar
I find myself carrying a Q7 + 06 and a +4 diopter close-up lens as a 'what-if' option. Takes up almost no weight or space and adequately covers both CU and tele options.
If the main body is set for tele situations the Q7 + 08 or 01 is a ready standby option.
05-05-2016, 08:50 AM   #9
TER-OR's Avatar
Thanks for that input.
One thing I do like about the sling is it allows for a loose shirt, and ventilation. The vests provide a lot more security though, so it's a trade-off...
I'll have to consider it. As for tomorrow, it will be two slings, swinging in the breeze! Hopefully not too much breeze.
As for the little pockets, check your REI type stores, they have small pouches designed to clip onto backpacks, belts etc. It might be enough for you. Think of small first-aid kit pouches.
---------- Post added 05-05-16 at 10:53 AM ----------
QuoteOriginally posted by pacerr Quote
I love the Q for that, particularly with the 01. For general use it's great, but not for the specialized use I have in mind with a long tele/zoom and long macro. Still, I should probably bring my Q more frequently.
05-05-2016, 09:12 AM   #10
dsmithhfx's Avatar
I haven't done this in a while, but I use separate straps, one around my neck and the other over one shoulder. This spreads the weight and reduces the risk of collisions. Generally though I just shoot with a lens for a while, get bored with the FOV and change lenses, I'm not looking to capture live action per se.
Forgot to mention that I *always* carry a stylus epic, so there's 35mm FL covered anyway. It weighs nothing.
05-05-2016, 09:16 AM   #11
I carry two bodies on a regular basis. Always my K-5 with battery grip and then I rotate between my K10D with battery grip or Km. Both K5/K10D have two batteries (carry extra battery in each battery grip) in them, so that adds weight.
Usually have a 55-300 on one and a a 12-24 wide angle on the other....or sometimes one of my Limiteds...21, 40 or 70. I just bought a Sekonic L-398 A, light meter and I plan to carry that with two bodies.
I don't notice the weight too much, but I'm a fairly large guy. I use the standard Pentax straps that came with the cameras and they work fine. I have a Canon G12 (very good camera) and I replaced the terrible Canon strap which was unsatisfactory. It came loose a number of times and I replaced it with a padded Optex, which is very good.
Both straps around my neck. One camera I carry in my hand, the other hangs by my front. I always have the straps around my neck as I don't trust my hand holding, alone without strap backup.
05-05-2016, 09:33 AM   #12
QuoteOriginally posted by lesmore49 Quote
I'm not a fairly large guy. I'm 5'7", with a fragile back (recurring disc trouble), a right hand with severed tendon in one finger, wonky depth perception and klutzy tendencies. I have broken my left wrist seven times, multiple bones in my feet and ankles, and several fingers. Let's not even talk about sprains.
Mr frogoutofwater, thankfully, is big, strong and agile - I believe he's part mountain goat. And while he'll be carrying his own Pentax gear, I can count on him to schlep a little for me and lend a balancing hand, at critical points, too. As my family often points out, I got the better deal in our marriage
05-05-2016, 10:01 AM   #13
bobell69's Avatar
QuoteOriginally posted by frogoutofwater Quote
I often carry my Lowepro Camera bag on my back as well with extra lenses and water etc. Without the two cameras in the bag, it is much lighter and easier to hike with. Seems balanced to me.
05-05-2016, 10:17 AM   #14
I know what you mean. The wear and tear our bodies go through as we age, can be something else to cope with.
I'm in my late 60's now and in the past decade, I've started to feel the effects, more than I have in the past. I mentioned in my post that I always have my camera strap around my neck as my hand grip ain't what it used to be. I have some nerve damage in my hand, along with a grip issue...think the medical slang is Viking grip...a couple of my fingers 'lock'.
I wear my camera strap around my neck, not my shoulders as I have shoulder issues...due to a decade of playing hockey (defense) ...also had a knee operation...hockey can be a rough, contact sport.
I'm thinking that as I get older, maybe I can find a camera 'caddy' ....kind of like some golfers have their caddy. A photo/ golf type cart....might even be better for me, although it probably would have difficulty driving through forest trails.
Nice to hear that you and your spouse are out and about, taking pictures. keep up the good work.
Les
05-05-2016, 11:21 AM - 1 Like   #15
I am much more into photography than he is, but we enjoy our excursions together. And he's very supportive of the volunteer work I do for rescues. Aside from participating in photo shoots with me, he's also going to frame 40 prints for me for a fundraising exhibition later this spring.
And he brings me coffee in bed every day.
PENTAX K-3  Photo
breeze, field, option, pouches, q7, tele, tripod, yeti
Thinking of changing my setup from big to small. Opinions sought. imaspy General Photography 13 04-21-2015 09:43 PM
How will you use dual SD slots? audiobomber Pentax K-3 & K-3 II 66 10-23-2013 10:24 PM
Kodacolor-X from Endangered Species - Opinions builttospill Film SLRs and Compact Film Cameras 7 08-17-2012 02:13 PM
Has anyone used the dual split image from jinfinance? Lowell Goudge Pentax Camera and Field Accessories 22 09-15-2010 08:15 PM
You opinions and thoughts please. Which do you like? Peter Zack Photo Critique 19 02-01-2008 01:04 PM
All times are GMT -7. The time now is 12:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
