As I understand it, the flash is for Canon cameras and apparently talks "canon". but would it work as a manual flash when mounted on a pentax, or will it not work at all? I am tired of running around with my normal flash hand held with a cord...
Right now I see a couple of different possibilities.
1. buy a cheap flash. ($100)
- have not found any manual and not sure the Yongnuo works.
2. buy old flash ($100 or less)
- not very common
3. buy new Pentax flash. ($500)
- expensive
4. buy new sigma or metz.($300)
- sigma flashes are a letdown for me, metz is the only option for me.
5. since I know someone will suggest it, a led ring
- not a path I want to travel.
6. DIY ring thingie to my current flash
- probably not, it seems like it is working rather bad
I really do not need any automatic stuff. My current setup is a 540 in a softbox with a cable and setting the flash is not an issue.... You see I'm holding a flash in one hand, camera in the other and trying to do hand held macro... thats the challenge
have you ever tried focusing while holding a flash and a softbox with the hand you need to do the focus with?
