05-27-2016, 10:00 AM   #1
Genki's Avatar
Which Filter are better, to use or not use with Pentax K3, Pentax K3II and Pentax K1?
Recently I read some information about Filters in a Pentax DSLR Cameras. Some Filters Brands they say, is good to use to protect the sensor (Like Heliopan UV/IR - UV/IR BLOCKER IMPROVES COLOR/SHARPNESS) others just Protect the Lens (Like Heliopan Clear Protection). Some others say are better not use anything.
So, The question is: Which Filter are better, to use or not use with Pentax K-3, Pentax K-3 II and Pentax K-1?
05-27-2016, 10:38 AM   #2
jatrax's Avatar
Nothing, waste of money IMHO.
If you feel better with a filter on get a good quality protection filter, uv blocking does nothing on digital.
05-27-2016, 10:41 AM   #3
Genki's Avatar
That's exactly what I think, for me made the picture worst and loose some sharpness.
05-27-2016, 10:44 AM   #4
BigDave's Avatar
If you are working in a dirty or hazardous situation, then using a UV filter for protection is a good idea. I know someone who worked with the local fire department taking pictures (while they were working) and after one fire he looked at the front of his UV filter and noticed an odd streaking. It was the multicoating that had gotten so hot it started oozing down the filter! The same would have happened to his lens if the filter was not there.
Any place with windy conditions where dust can be thrown at the lens, or any other number of things can get on the front lens element, I would suggest a UV filter. Just make certain it is multicoated. Other than that, they are generally not necessary and can cause issues with sharpness by introducing another surface to catch light and create lens flair. If shooting into the light, I would not recommend a filter unless it is necessary for the image (polarizer, graduated ND, etc.).
PS- a good quality optical glass filter also filters a fair amount of UV, so clear and UV may do the same thing!
Regards,
BD
05-27-2016, 10:50 AM   #5
Genki's Avatar
QuoteOriginally posted by BigDave Quote
Regards,
BD
I agree. I tried to take some pictures with Heliopan UV/IR a night and I noticed some flair and loose some sharpness.
05-27-2016, 11:06 AM   #6
Circular Polarizing filters make some sense in the digital age. So do neutral density filters.
There are some very strange color filters that make sense with film. Some work better with color film and some work better with B+W film.
05-27-2016, 11:35 AM   #7
IgorZ's Avatar
The other question is price and quality. I have heard people say one should buy an expensive filter, otherwise one wastes the lens potential. Then I saw a review where there was no correlation between price and quality. More expensive filters were not consistently better, than cheap ones...
05-27-2016, 11:37 AM   #8
Genki's Avatar
QuoteOriginally posted by aoeu Quote
To keep a filter everyday without changed, I believe protection filter are the best idea to keep your lens clean and protect the value against any environment moisture.
05-27-2016, 11:58 PM   #9
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by IgorZ Quote
Check shots you take in RAW of a white surface with a cheap ND filter. You don't want a colour cast, such as green.
05-28-2016, 03:49 PM   #10
mee
Polarizer and Neutral Density are still useful on digital. UV are not since that was a film-only issue.
05-28-2016, 08:26 PM   #11
sherrvonne's Avatar
Hopefully I'm not asking a stupid question: Can you tell just looking at it on the camera review screen or is it necessary to look at it in raw from a computer view screen in Lightroom etc?
05-28-2016, 11:41 PM - 1 Like   #12
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by Genki Quote
The one you leave at home...
Apart from occasional specialist uses, likes of ND or polarisers.
For protection and improved contrast, lens hoods are the way to go.
05-29-2016, 12:07 AM - 1 Like   #13
newmikey's Avatar
QuoteOriginally posted by Kerrowdown Quote
For protection and improved contrast lens hoods are the way to go.
+1
UV and so-called "protection" filters are expensive nonsense.
05-29-2016, 06:29 AM   #14
True enough, although that's usually easily fixed during RAW processing using the eyedropper.
Personally, filters were more useful when shooting film. Digitally I find ND grads and polarizers the most useful, "protective" filters like the UV a waste of time and money, and certain specialty filters like the blue-gold useful only when going for a specific effect. (Watch early episodes of CSI Miami and it's obvious somebody fell in love with the tobacco filter hee) So to the OP, don't spend money on any filter unless you can name what you hope to achieve by using it.
05-29-2016, 04:08 PM   #15
MadMathMind's Avatar
QuoteOriginally posted by silvershoes Quote
Much of this can be accomplished in camera with clever use of white balance. If you want to make a forest seem like night on an overcast day, set to Tungsten and underexpose a stop or two. Watch the magic
dslr, filter, filters, heliopan, k-3, k1 - filters, k3, k3ii, lens, pentax, pentax k-3, pentax k3, tripod
(Update) Use of Pentax mount SIGMA interchangeable lenses when attached to the K1 OoKU Pentax News and Rumors 202 04-13-2017 04:28 AM
Which Lens are better to K3:Pentax 43 - Pentax 55mm - Sigma 35mm Art - Sigma 30mm Art Genki Pentax K-3 & K-3 II 20 05-13-2016 12:15 PM
Which Support for K3II Astrotracer or Pixel Shift Feature Use C_Jones Pentax Camera and Field Accessories 33 11-25-2015 12:40 PM
Which camera/brand did you use before switching to Pentax and why? axelm7 Pentax DSLR Discussion 105 11-25-2014 10:18 PM
Advice on which to purchase, Pentax K-5IIs or Pentax K3 DCphotog Troubleshooting and Beginner Help 16 08-19-2014 07:26 AM
All times are GMT -7. The time now is 09:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
