Originally posted by othar But are you sure the vignetting you get is because of the number of stacks and not the usuall vignetting you get because of the 10 stop darkening.
the problem of the da15 is that it needs a uv filter to pass the hood, a step up ring to 58 and only then you can stack the filters that matter. I can add cpl + 10stop ND without a problem, but beyond that is a problem. So i don't think it is the 10stop itself causing vignet.
Guess it is just something to take into account. Ofcourse this is a specific da15 issue.
But even with the fa31 (not really a problem on apsc since the lens is FF), but on FF the specific built (hood..) might cause issues when stacking more than two filters.
Its just something to be aware of.
A square filter holder might be safer and better in the long run.
Putting filters in doesn't really take long vs having to screw them either.
