I'd been looking for a tripod ring for the 300 and did some searching around Canon and Nikon gear to see what they had. Canon produces a ring that fits the lens well. Just enough room for the window and the aperture ring although you won't be able to move the ring easily once the lens is mounted on the camera. It will fit further forward over the window but then the barrel diameter changes. So the clamp is not as tight. But the screw is long enough to do this. Solid all metal ring. Fairly decent deal even if the shipping was too much. Lock on the lens perfectly and the colour match is very close.
Bonus is that the Canon logo is on the back and hidden by the grip (but I'll cover it anyway).
Second is a data base that we should expand for lens hoods.
Nikon Brand metal and I have one for my FA50mm Macro. Locks on great, easy to remove and reverse. Lens cap works on the back when reversed. Looks good as well. Best hood I've found so far. Here are some common models and hopefully some here knows of a 49mm size version (but you could use a step down ring just fine).
Tripod Mount Ring 4 Canon EF 70-200mm 300mm 400mm lens - eBay (item 180255729010 end time Jun-26-08 05:08:58 PDT)
