07-14-2016, 12:19 PM   #1
charliezap's Avatar
Am I weak?
I just got my Benro TMA48CL48A tripod and it's a beauty.Maybe I'm getting weak in my old age but for the life of me I can't unscrew the foam leg to make it into a monopod.
DMC-TZ4  Photo
DMC-TZ4  Photo
07-14-2016, 12:27 PM   #2
BigMackCam's Avatar
I wish I could help... I will say, though, that's a fine tripod you have there!
07-14-2016, 01:00 PM   #3
jatrax's Avatar
Nice tripod! Maybe there is a release catch to open before unscrewing?
hate to say it, but you might have to read the manual.
Or use a pipe wrench
07-14-2016, 01:21 PM   #4
charliezap's Avatar
The instructions say that it simply unscrews. I'll wait until my younger stronger neighbor comes home.--charliezap
07-14-2016, 01:39 PM   #5
UncleVanya's Avatar
It may have been over-tightened in the initial assembly.
07-14-2016, 01:42 PM   #6
charliezap's Avatar
I called up the Benro # and I was told that this tripod does not unscrew to make a monopod even though the instructions show otherwise. The cheaper Benros do unscrew--charliezap
07-14-2016, 01:46 PM   #7
BigMackCam's Avatar
QuoteOriginally posted by charliezap Quote
That makes sense, I guess... but - silly question, perhaps - why does that leg have a foam grip at the top and the others don't?
07-14-2016, 01:50 PM   #8
Senior Moderator
Parallax's Avatar
I'm guessing that leg is the monopod he's referring to on the ones that do unscrew, but seems useless in this case.
07-14-2016, 02:11 PM   #9
charliezap's Avatar
I did further research and one of the reviews on this tripod say that it does not convert to a monopod.Good thing that I didn't get the pipe wrench.--charliezap.
07-14-2016, 02:19 PM   #10
jpzk's Avatar
Well, you've got quite a gear here, Charlie!
You'll have to dig into your retirement fund and get a monopod !!
07-14-2016, 02:32 PM   #11
LensBeginner's Avatar
It's better this way, one less screw/joint/watever that can get loose or break, it's sturdier this way ;-)
Enjoy!
07-14-2016, 02:56 PM   #12
Imp
Imp's Avatar
Theoretically, you only need one. If its a metal tripod and its cold, you only need one grip to carry it. If you're carrying it on your shoulder, you only need one leg padded. Theoretically
Although in my view, I'd want all three legs to be padded! I don't see that it would be much more expensive, or much more bulky/heavy.
So, to answer your question - who knows?
07-14-2016, 03:23 PM   #13
ramseybuckeye's Avatar
Congratulations Charlie, that's a great looking tripod! Maybe you're unscrewing the wrong leg. Or it may be a southern hemisphere thread and you're turning the wrong direction!
My Induro also has one leg with foam, it's a cold weather handle.
07-14-2016, 03:53 PM   #14
AggieDad's Avatar
I have the aluminum version of this same tripod. I agree - it is awesome.
I grabbed a piece of foam pipe insulation at Lowes and now I have foam on all three legs of my Benro. Works a treat.
07-14-2016, 05:45 PM   #15
QuoteOriginally posted by ramseybuckeye Quote
That's right. That is what my Sirui tripod has also as a carry/cold weather handle.
tripod
HI,I am with K5ii, I am just new here fuenqing Welcomes and Introductions 14 03-30-2015 08:24 AM
I Am Weak... (LBA) ajuett Pentax SLR Lens Discussion 26 04-02-2010 12:46 AM
Pentax K7 Price Watch? Or I am waiting because I am a cheap, errr, frugal SOB thread brecklundin Pentax DSLR Discussion 240 03-26-2010 10:01 AM
Am I asking for too much?! Am I being bamboozled?! jshurak Photographic Technique 39 03-12-2008 01:41 PM
I am so weak... need help!!! ACImages Pentax DSLR Discussion 3 01-03-2008 02:24 AM
All times are GMT -7. The time now is 07:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
