Originally posted by urssu
Questions about the leg release system for the Manfrotto:
- Does it hold (the legs don' t collapse alone) ?
- Did it get loose in time and meeded retightening?
- Also, did you get dust, sand, leaves or whatever in the clamping system?
- If so, how easy was it to clean?
I think those questions are addressed to me so:
1) my Manfrotto is a 3221 purchased maybe later 1970's. The lever locks on it have never slipped, do not slip now, and they do not have adjustments;
2) my Slik 444D is even older, the lever locks have never slipped, do not slip now, and they do not have adjustments;
3) I have two relatively new tripods with flip locks: A) a Giottos carbon fiber Silk Road ultra light and compact tripod I use when traveling by plane; the flip locks have loosened and can be tightened with a supplied Allen wrench; B) a steel Sirui which is larger and heavier, with very similarly designed flip locks which is my preferred general-use tripod locally; the flip locks are nearly identical to those on the Giottos but have never needed retightening despite the fact that the tripod is used more;
4) the Gitzo 1228 carbon-fiber tripod with collar locks from the outset needed a very hard twist to insure the legs would not start collapsing. Eventually it became almost impossible to prevent the smallest leg section from sliding back in, so after several weeks of searching I finally found a source of new friction pads (in the UK). I dismantled all the legs, cleaned everything thoroughly, reassembled with the new friction pads but still the smallest leg section is prone to slipping back unless the collar lock is given a really hard twist. Because of that, I almost never extend that small section and rarely use the Gitzo any more because I don't trust it (what if it started to collapse while my back was turned?).
5) Slik makes a wide range of tripods, legs only and with a head, steel and carbon fiber, mostly collar locks but some flip lever. Best way to see the line is go to B&H even if you cannot order from them, and search "Slik tripod."
If I were advising on a tripod and price were no object, I'd say that Manfrotto's 190 and 055 series are the best currently available (Slik is lower priced, and as noted, at least here the prices for Gitzo are absurd). Which of the many models to select?
1) for lightest weight and most compact: the 190 with 4 leg sections in carbon fiber;
2) for maximum stability at most reasonable cost: the 055 with 3-leg sections in steel.
3) get the tilting central column if you anticipate a lot of flowers, insects, ground-level and the like; otherwise do not pay for it.
UNDER ANY CIRCUMSTANCES, I would take flip locks over collar locks. IMHO they are quicker and more secure. If you have flipped the lever, it is locked, but how much tightening of a collar is enough? Does the smallest section need a firmer twist than the largest? If you are tightening a smaller section, have you tightened the next larger section enough to prevent that section from turning instead of the collar locking? I DO NOT LIKE collar locks.
For a ball head i would recommend considering: 1) Sirui; 2) Manfrotto hydrostatic; 3) FLM (wide range of prices, chose by weight capacity* and include an adjustable friction control); 4) Benro.
*a rated capacity of about 17 pounds is more than sufficient unless you anticipate using a 300mm or longer telephoto, BUT, the higher the load capacity, the easier it is to lock a head securely, and a head with a larger ball is usually a little smoother/easier for framing.
