I'm hoping for a miracle solution of this problem. I want to figure out a way that I could preattach quick release plates to camera bodies, a K 3 and k 5 ii, and a pentax 150 - 450 zoom lens so I could switch them quickly between a monopod support and my tripod
The tripod is a mx 1000, Vivitar I believe
I will supply the make of the monopod later
right now the quick release plates are not compatible
Thanks for any help or suggestions you can give
