As mentioned Nikon hoods HS-7,9 (and possibly/likely any of the HS-# hoods) are snap on/can be reversed, and the nice thing is reversed you can also put on a Nikon lens cap (the older ones with push tab on one side work this way). These are originally for 50mm lens FL. They also made HS hoods for 85mm and 105 mm FL's. The following site has data on most older Nikon hoods <
Nikon Lens Hood Specifications - Rick Housh >
For wider FL the takumar square 28 mm f/3.5 clamp on hood can be reversed, and as I recall the 24 mm hood is also a clamp on and thus can be reversed.
For all the above sometimes a filter ring (remove the glass) can be useful, or needed--where a step up/down ring is used.
---------- Post added 08-28-16 at 02:09 PM ----------
About the 35mm lens. I tried the HS-9 Nikon hood on my 35mm f/2 SMC (K) lens and it does not vignette (on a 1.5x cropped sensor), and it reverses fine. Couldn't find my HS-7 hood to try but I would think it would also be OK (as I recall it is a shallower hood).
Correction--per the above (late) Rick Housh compilation of NIkon hoods, the HS-7 is deeper (and wider), although still likely to be OK on 35mm lens; however, I still haven't found mine to check it.
