07-25-2008, 01:13 PM   #1
slowpez's Avatar
Remote shutter release problem
I just purchased a remote control shutter release for my K100D super and it doesn't seem to work all the time. Under Fn, it is set to remote control, AF in remote control is set to on. Sometimes it fires OK but sometimes it does nothing. When set to 3 sec delay, nothing happens. It will usually fire if I point it right at the flashing red light on the front of the camera.
Is this a bad unit or have I missed something in my camera's settings.
Thanks, Susan
07-25-2008, 01:26 PM   #2
Ole
Ole's Avatar
Try with AF set to off. I'm just guesing here. I have never had an issue and use manual focus when I use the remote.
07-25-2008, 01:37 PM   #3
slowpez's Avatar
Thanks for the quick reply Ole, I changed the setting and there is no difference. Am I wrong in thinking that you can stand behind the camera and use the release or does it have to be line of site? Works if I am standing on the right side of the camera or directly in front of it but not if I am behind it or on the left of the lens.
Thanks again, Susan
07-25-2008, 03:20 PM   #4
Hi Susan
Re your question:
I don't actually own a K100D Super myself, but I'm pretty certain that you have to trigger the camera's remote sensor by aiming your remote-control device directly (or at least within a minimum specified angle) at the sensor (i.e. line-of-sight). The more expensive K10D/K20D DSLR bodies have an infra-red sensor on both the front AND rear of the camera body, which would have made life a great deal easier for a you in this situation ! Simple answer.....
UPGRADE $$$$$.....LOL !
Best regards
Richard
07-25-2008, 05:44 PM   #5
You do actually have to make sure the beam gets to the camera for it to work. If you're out on the field or in an open space, you will have to aim at the front of the camera. If you're in a room, chances are you can bounce the signal from a wall, mirror, even a TV screen or picture frame.
Just make sure your remote has new batteries and that you're close enough. After all, most remotes are just not powerful enough to go too far and a nearly dead battery will make it worse.
Also, don't expect the IR to work all that great under full sun, or if the sensor is getting hit by direct sunlight.
07-26-2008, 07:34 AM   #6
slowpez's Avatar
QuoteOriginally posted by Confused Quote
Hi Susan
Simple answer.....
Best regards
Richard
Thanks Richard and everyone else for their responses. Now, if each of you would send a small (I mean large) check with your response, I will take advantage of Richard's suggestion and upgrade.
Susan
07-26-2008, 07:41 AM   #7
Moderator Emeritus
A donation is currently being evaluated by the finace team.
I was also going to offer the battery suggestion as well as outside in strong sunlight. Replace the battery with a good name brand and try it indoors first within about 15 feet, then try outside and see if there is much diffference.
07-27-2008, 10:44 AM   #8
slowpez's Avatar
QuoteOriginally posted by Peter Zack Quote
I was also going to offer the battery suggestion as well as outside in strong sunlight. Replace the battery with a good name brand and try it indoors first withing about 15 feet, then try outside and see if there is much diffference.
Peter, Let's hurry the finance committee along.
The remote is the tiny one that doesn't have batteries you change yourself. I did a search on the forum (should have done that first) and I'm pretty sure you have to be in line with the sensor.
Thanks again all.
07-27-2008, 11:53 PM   #9
maybe you should try getting one of those rf wireless shutters
no need for line of sight, and the range is far greater, and you can do long exposures and normal timed shots without needing to change the drive mode in the camera
a lot cheaper than upgrading the body
dave
07-28-2008, 05:27 PM   #10
madbrain's Avatar
Susan,
QuoteOriginally posted by slowpez Quote
Susan
You do not have to go to the expense of a new camera ! There are much cheaper solutions.
I have a K200D which only has an IR sensor in the front.
I use an IR reflector combined with a lens leash.
This will allow you to trigger shutter release from behind the camera.
A lens leash (type 2, with elastic) costs $1.99 at Ritz Camera.
http://www.ritzcamera.com/product/221661119.htm
They show out of stock right now online, but go to your local Ritz camera and ask for it. I got some for all 4 of my lenses.
I got my IR reflector with my IR remote direct from china on ebay.
10M Remote control for Pentax K10D K200D K20D GX-20 E F - eBay (item 360055874175 end time May-29-08 03:39:31 PDT)
Cost of the remote with shipping : $8.98
You can thank me by sending me the amount of your K10D/K20D fund that you won't need to spend
07-29-2008, 07:17 AM   #11
slowpez's Avatar
QuoteOriginally posted by madbrain Quote
Susan,
Madbrain, I know where you got your name from. I am keeping all the money Peter has gotten for me and spending it on the K30D (bound to be one).
Thanks for the other suggestions though. Susan
control, release, shutter, shutter release, tripod
Flashwave 2 as a remote shutter release joshnl Flashes, Lighting, and Studio 0 07-27-2010 04:50 PM
Remote shutter release on ZX-60 noahpurdy Pentax Film SLR Discussion 5 03-03-2010 08:19 AM
K-m remote shutter release modizzy Pentax DSLR Discussion 0 12-22-2009 06:03 AM
Wireless Remote Shutter Release jqjones Pentax Camera and Field Accessories 8 11-20-2009 08:39 AM
Remote shutter release for K100D smf Pentax Camera and Field Accessories 2 02-06-2009 11:37 AM
All times are GMT -7. The time now is 04:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
