Check out this widget:
Fotodiox Lens Mount Adapter Pentax K AF Lens to MFT (Micro-4/3, M4/3) Mount Mirrorless Camera (such as OM-D E-M10, Lumix GH4, and BMPCC) w/ Aperture Control Dial - Adapters
This is a m4/3 <=> pk adapter, with an "aperture control dial" that lets the user stop down the lens. What the lever seems to do judging by the comments is push the aperture open and closed as you adjust it. So first of all my guess would be that this piece of apparatus is useful for more modern Pentax lenses that don't have an external f/stop ring. If you wanted to reverse and use one of those it might be useful - just use it as a reverse aperture controller, forget that it's a m4/3 thing. "Although the lens will fit physically, automatic diaphragm, auto-focusing, or any other functions will not operate correctly while using this adapter. In this case "stop-down mode" will need to be used when metering since the lens does not have the ability to have its aperture controlled by the camera body. You can shoot with manual mode or aperture priority mode micro 4/3 body. Infinity focusing is guaranteed." A macro cheat for folks who have modern lenses without aperture rings who want to use them reversed... and don't want to use a piece of rubberband/paper/whatever to keep the aperture closed.
BUT
What I'm after is a tad different, a bit more. What I'd like is a piece of apparatus that is like the one above, but with the added feature that it stops down the aperture when taking the pic. I don't have the skills to make it myself. I believe that all it would require some sort of tiny transmitter firing off a flash signal (ie sitting in the flash shoe) to some small battery operated servo on the adapter that'd push that aperture pin closed during the actual shot. Surely can't be that hard - and would mean you wouldn't have to try and focus with a stopped down aperture (which is a pain).
If I buy the component and parts, is there anyone on this forum with the skillz neccessary?
