11-29-2016, 12:03 PM   #1
What's the point of the SD card write-lock?
Okay, so obviously the point is to prevent you from accidentally writing data (like formatting the card or something). But...does anyone use this as part of their workflow somehow? I just noticed it, and now it sticks out like a sore thumb on all of my cards.
11-29-2016, 12:15 PM - 1 Like   #2
Buffy's Avatar
Re: What's the point of the SD card write-lock?
QuoteOriginally posted by lithedreamer Quote
I have not used it for some time since cards are fairly large now, but back when I carried multiple small cards I used the write lock to indicate that a card was full so I didn't accidentally re-use it before I could upload it's contents to my computer.
11-29-2016, 12:57 PM   #3
richandfleur's Avatar
When I do anything super important, like travel, or anything at a wedding etc, I use this when I swap out cards.
As above though, less of an issue now with the larger capacity cards. But even then I sometimes swap cards to ensure any corruption doesn't take out the whole cards contents.
11-29-2016, 01:01 PM   #4
narual's Avatar
I mostly swear at it repeatedly. Something in my K3 catches it about 1/3 of the time I put a card in there (or maybe when I take it out, I've not paid that much attention) and then I can't take pictures
11-29-2016, 01:01 PM - 1 Like   #5
I personally dislike the tab because it always gets engaged on accident.
11-29-2016, 01:51 PM   #6
I used it to lock full cards, too. But as the K-1 is delivered without a usb-cable i now lock the cards before inserting them in the card reader... i don't trust windows and think i might lessen the tiny probability of a failure on the next trip.
11-29-2016, 02:03 PM   #7
amoringello's Avatar
I've had several break off. I had to use epoxy on a toothpick to "rebuild" the tab.
An ancient hold-over from floppy disks, if anyone remembers what those were.
Not useful if you can't punch a hole in the other side and double your capacity. ;-)
11-29-2016, 02:08 PM   #8
p38arover's Avatar
I use it when travelling. It's a quick way to check if the card has images on it. I usually change cards daily. If the card is corrupted, I only lose one days images.
I've also returned to smaller capacity cards for the same reason - I can lose fewer images. I have had cards get corrupted.
11-29-2016, 02:27 PM   #9
Otis Memorial Pentaxian
It can be useful, but is not fail-safe. Write-lock compliance by readers is optional and may not be complete depending on host operating system.
card, sd card, tripod
Write speed SD card - test 88lukas88 Pentax K-1 & K-1 II 7 06-16-2016 07:40 AM
What's the point of variable aperture in small-sensor cameras? BigMackCam General Photography 23 01-24-2016 03:20 PM
What's the point of f/22? 6BQ5 Pentax SLR Lens Discussion 23 08-04-2013 10:28 PM
What's the fastest SDHC card the K5 can take advantage of? SenorBeef Pentax K-5 & K-5 II 5 06-23-2012 05:55 AM
What's the point of the Green Button? herzzreh Pentax DSLR Discussion 22 01-24-2008 07:09 PM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
