11-30-2016, 11:35 AM   #1
BruceBanner's Avatar
Cap suggestions to go over step-up threads...?
I recently bought a 21mm landscape lens that needs a 49-52mm thread step up in order to use my rather pricey Promaster variable ND filter. I'll likely use this filter a lot on this lens so I'm not sure how often I will bother to remove the step-up off the lens. I could keep the step-up ring on the filter, but then I do have a 50mm lens with the right thread size to take the filter, so I think the stepup ring left on the lens is best.
But now I'm wondering what kind of lens cap can fit on a 21mm lens with a step up ring attached?
Also, while we're at it, I'm still housing my ND filter in the plastic container it came with... it's not that great. Is there a nice container available for something like an ND filter?
Cheers,
Bruce
11-30-2016, 12:01 PM   #2
pete-tarmigan's Avatar
A cap designed to fit a 52 mm diameter lens?
11-30-2016, 12:04 PM   #3
QuoteOriginally posted by pete-tarmigan Quote
lol... ok I feel dumb now.
okok, what about nice filter cases, do they exist?
EDIT: A quick look on B&H shows quite a few, I can't see any single hardcase ones tho, just soft pouches that are designed to take a few...
11-30-2016, 01:56 PM   #4
QuoteOriginally posted by BruceBanner Quote
They're a little expensive, but I really like Mind Shift's Filter Nests. The Mini Filter Pouch is good if you only have a total of four or fewer step-up rings and filters. I like the Filter Nest Storage Case more, but it's overkill unless you have more filters and rings.
12-01-2016, 09:16 AM   #5
I haven't found any either, despite scouring the 'net.
12-02-2016, 01:26 PM   #6
QuoteOriginally posted by lithedreamer Quote
Yeh this looks alright Filter Nest Mini - camera lens filter pouch wallet case | MindShift Gear
12-02-2016, 02:28 PM   #7
photoptimist's Avatar
What's wrong with the box it came in? Perhaps you can find a cheap 52mm UV/skylight that comes in a better plastic box or holder.
Solution 2: Get two used skylight filters from where ever (they usually come free on the used lenses I buy) and use them as end caps. Sure it's a minor hassle to do two unscrewings to get to a specific filter, but the stack is really compact in my bag (I have 5 filters plus the 2 junk skylight filters) and the screw-on filters won't pop-off like a regular lens cap can.
Personally, I would avoid any soft wallet or bag-like filter holder. Grease, dust, & grit will get on the material and will transfer and drag across the surface of the filter.
12-02-2016, 02:34 PM - 1 Like   #8
With modern filters and filter wallets, I've never found this to be an issue.
12-02-2016, 02:42 PM   #9
Some good ideas there! Yeh, I think I will just stick with the plastic box it came in, I think it just needs some TLC inside with some more padding etc.
This is the case it came in; ProMaster 55mm Variable ND - Digital HGX Filter 9315 | eBay
I don't know, my case might just be a bit naff, there isn't a satisfying 'click' when you close it etc, really I would be happy for something like this, just better (but no zips! I'm scared of zips lol).
21mm, cap, cap suggestions, container, filter, lens, step, step-up, thread, tripod
Step Up or Step Down Adapter Big T Pentax SLR Lens Discussion 5 09-09-2012 07:48 AM
Heliopan 54mm to 55mm Step-up #190 Votesh Ask B&H Photo! 4 06-22-2010 04:03 PM
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
step-up or step-down rings? ncrecordkeeper Pentax Camera and Field Accessories 8 05-13-2010 07:31 AM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 01:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
