12-04-2016, 08:23 AM   #1
Brucie's Avatar
K-5 battery charger adapter for Caribbean travel
Hi Everyone,
I'm planning a trip overseas and am told to bring an adapter for all my electronics that will allow me to plug into "European style" outlets. The hotel where I'm staying uses US-style 110 volt (60 cycle), as well as 220 volt (50 cycle), and European-style two-prong round plugs. Not sure which of these I'll find in my room, so I want to be prepared.
The charger I bring needs to be "multi current."
Can anyone recommend an adapter for use with the Pentax K-5 camera battery charger, that will allow me to use the 220 volt and/or European-style two-prong round plug?
Thanks in advance!
Brucie
12-04-2016, 08:32 AM - 1 Like   #2
Pentaxian At Large
robgski's Avatar
The specs on my K-5 charger state 100-240 Volts, you won't need an adapter. Which is pretty common for most electronics manufactured outside the US, it's cheaper to buy/manufacture multi-voltage battery chargers to package with the devices than it is to have a separate line of chargers for each country/region.
Places like Target sell adapters for US plugs to fit into other outlets.
12-04-2016, 04:23 PM   #3
Just to elaborate on what robski said, the Pentax charger is capable of handling any type of power source. The only thing you need is a physical adapter to let you plug your 2-blade US cable into a 2-pin European outlet. Some like this: https://www.amazon.com/dp/B0036VJ1OQ/
Note that you should not use such an adapter with a device that only works with 120V, e.g. a lamp or something with a motor. But the vast majority of electronics will work. Always read the label on the device to be sure, it is usually printed as "Input".
12-04-2016, 09:18 PM   #4
Be aware that there is not a "European" style, the British, of course , have their own plugs. Depending on where you travel you may need more than one adapter.
12-05-2016, 01:47 AM - 1 Like   #5
A K-5 D-BG4 battery grip (or clone) with an AA battery tray in it may also help.
AA batteries are internationally available.
12-05-2016, 01:56 AM   #6
p38arover's Avatar
To Which countries in particular are you travelling?
Once you have that list, look here: Plug & socket types - World Standards
12-05-2016, 03:41 AM   #7
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by Brucie Quote
Hi Everyone,
Thanks in advance!
Brucie
to answer your request for a specific recommendation - this is what we took to Holland and Tanzania (please don't ask me what any of the stuff below means and I am not saying that you need it: an adapter plug (US style to the "foreign" style) may be all you need)
Bestek 200 W Portable power Adapter and Converter
model MRJ201GU,
which has marked on it the following:
INPUT VOLTAGE: 90-240 VAC 50/60 Hz,
OUTPUT: 200 W RATED, 230W MAX
OUTPUT: 100 - 120 VAC 60 Hz
(2 X 2.4 A, 2 X 1A)
4 X USB PORTS OUTPUT: DC 5V/4.2A rated (5v+-0.25V/6.0a max)
it has 3 x multiple prong (3) ports, 4 USB ports and the unit came with physical adapters for the different physical plugs you might find through out the world.
it is about the length of a dollar bill (+/-) and 1.5" thick plus a 3 ft +/- cord.
I would also recommend taking at least 1 multi prong plug (3 prong/ground) We always called them a "cheater" plug because you plugged in a 2 prong plug into it and then the whole thing into a grounded electrical outlet
12-05-2016, 03:50 AM   #8
p38arover's Avatar
That converter would be pretty useless in most parts of the world, including Holland and Tanzania - it can't handle 220-240 volts input.
It looks like its main use is to ensure you get 60Hz output when the input is 50Hz.
Are you sure the input reads 90-120v?
I'd better go and check it on the 'net.
12-05-2016, 03:56 AM   #9
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by p38arover Quote
if that is directed to me, I don't know electronics.
all I know is that It is what worked for us with no problems at all in Holland and Tanzania, that is all i know. the nice thing about it was it gave us the ability to plug in multiple electronic devices into it while only needing one wall plug
WHOOPS, NO COFFEE YET,
240 VAC
thank you very much for your help. I have corrected the error in the original post.
12-05-2016, 04:02 AM   #10
p38arover's Avatar
Aha! That's betterer
12-05-2016, 01:24 PM   #11
Brucie's Avatar
Thank you all for the replies! I appreciate your help.
adapter, adapter for caribbean, battery, battery charger adapter, charger, cycle, k-5 battery charger, round, tripod, volt
K-5 battery on a K20D charger Matjazz Pentax Camera and Field Accessories 5 09-28-2012 01:27 AM
Lens rental recommendation for travel to Caribbean Billium28 Pentax SLR Lens Discussion 8 06-14-2012 09:28 PM
For Sale - Sold: New D-BC90 battery charger + k-5/k-7 accessories (CONUS) acrollet Sold Items 3 09-22-2011 01:56 AM
For Sale - Sold: K-7/K-5 battery and charger, 49mm filters, Films zhuxyg Sold Items 2 09-18-2011 04:11 PM
All times are GMT -7. The time now is 05:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
