Just got back, too late now, will have a look at it tomorrow, cheers
Ok.
Originally posted by Driline Curious as to what you pack into your Hadley Pro Large? And how deep is the flap on the large? Is it wider than the regular Hadley Pro at 3"?
It is just a little over 4" at 110cm across from back to front depth, height is about 270mm, and width from left to right across the bag is about 345mm, these are approx. internal measurements.
I bought this bag when i had the 60D and 70-300 and two other lenses, the height was good for the 70-300.
These days I can carry the K-3 or K-5 with attached lens, lens facing down, bag divided into 3 sections, and I made up some square pieces of foam for dividers so I can carry several smaller lenses, stacked, as well. It works ok, but for taking out a few lenses with a body I am still leaning toward the fstop 1.4 as a day bag.
as a side note the other one I was considering is the Ona Bowery bag, but maybe too small.
Reason: ad info.
