12-24-2016, 11:37 AM   #1
pentax limited case 2 and the 3 amigos + a friend
just curious if anyone has the pentax limited case 2 (not the original, the version 2 holds all 5 da limiteds apparently) and is using it for the 3 amigos + another prime
basically, i'm looking to get a case for my primes to make packing them a bit easier. the limited 2 says it's 2x2.5x11.5"
will this hold the 31/43/77/da15? if need be i'll get some op/tech dual lens caps and marry the the 15/77 and 31/43.
my concern is the 31, it's a bit thick compared to the others.
---------- Post added 12-24-16 at 12:19 PM ----------
the four lenses stacked on top of each other measure exactly 11" so length wise there should be room for them plus a divider. just need to know about the 31 really. it's 2 3/4 wide at the cap, which may be a bit much i'm afraid
12-24-2016, 01:05 PM   #2
Tako Kichi's Avatar
I use the 11" version of this and really like it: Accessory Pack | OP/TECH USA
It holds my 3 Limiteds (21, 40 & 70), my DA 50 F1.8 (plus add-on hood), lens pens, small blower brush, spare battery, spare body/rear caps, SD card holders and other stuff too. It's well made and easy to carry. I found the strap to be a little narrow for my liking as I have some health issues and it tended to cut into my shoulder when loaded (no natural body padding, I'm just skin and bone!) but I picked up a cheap seat belt pad from Walmart and it wraps nicely around the strap and feels really comfortable now.
12-24-2016, 03:06 PM   #3
Saltwater Images's Avatar
Another bag to consider for a 4-Prime configuration is the Lowepro ViewPoint CS 60: ViewPoint CS 60 Camera bags, backpacks and rolling cases. Although it was designed for a GoPro kit it carries Pentax primes very well.
I picked one up for my 21-40-70 stack of pancakes with the intention of adding the 15mm after Christmas. What I like about the ViewPoint is I can put it in an outside pocket of my Domke F-4AF bag leaving room for 2 large zooms inside the bag.
12-24-2016, 03:10 PM   #4
all good suggestions, but i'm looking for something to hold the primes snugly that i can tuck into my normal backpack. not necessarily something to carry them on their own over my shoulder.
does anyone make a dual lens case with a zip on each side? that might work well for stacking.
12-24-2016, 04:44 PM   #5
noelpolar's Avatar
I use my socks.... when travelling..... always upsets the limiteds on the way home.....
12-24-2016, 04:57 PM   #6
Tako Kichi's Avatar
You may find some useful info in this thread posted back in 2014: https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/273575...beautiful.html
Lots of alternative options were brought up then including using dollar store neoprene pencil cases. I find dollar store neoprene cases to be a great source of material especially the ones meant for iPads and tablets. I have bought several of the tablet size ones and then de-constructed them so that I could re-use the material for something else (I can use a sewing machine so that helps! ). I have used the material to make lens pen cases, covers for my tripod tool kit to stop it clanking against the tripod legs, a pouch to hold my binocular tripod mount so that I can store it in my binocular case without damaging the binos, shoulder pads for case/camera straps, etc., etc., etc.
---------- Post added 24th Dec 2016 at 18:58 ----------
QuoteOriginally posted by noelpolar Quote
EWWWWW!
Athletes foot infection of your Limiteds!
12-24-2016, 05:31 PM   #7
noelpolar's Avatar
QuoteOriginally posted by Tako Kichi Quote
I can use a sewing machine....
Only "Real men" sew.... a mans sewing room is called a sail loft...
12-24-2016, 05:53 PM   #8
Tako Kichi's Avatar
This is very true....or a kite loft! My wife and I were into designing and building large kites a few years back until my illness forced me off the flying field.
My user name is kite related and is Japanese for 'kite crazy'. We have a number of sewing machines but our favourites are a heavy duty Husqvana Viking from the 1970's and a 1980's Pfaff.
12-24-2016, 08:11 PM   #9
UncleVanya's Avatar
I have the three lens case. I also own the FA 31 and 77. I can check the 31 later.
12-25-2016, 08:25 AM   #10
Mikesul's Avatar
I have two of the cases. One contains the DA ltds and the other the 3 FA ltds. They fit nicely and are very well protected in these cases. I have to put one of the DAs at an angle to make them all fit but it is not a problem. The case comes with an ample number of cushions and dividers to make everythig fit snugly.
amigos, binocular, bit, dollar, limiteds, neoprene, pentax, store, tripod
Macro Going macro - a small use and show case (Achromat +3) acoufap Photographic Technique 10 01-24-2016 03:00 AM
Which one of the 3 amigos should I sell? TroutHunterJohn Pentax SLR Lens Discussion 47 11-20-2015 10:01 AM
Wanted - Acquired: 3 Amigos! FA 31, 43 and 77 L33tGreg Sold Items 7 07-18-2012 10:38 AM
For Sale - Sold: Tamron Adaptal 2 28mm 2.5 and 24-48mm 3.5-3.8 with PK/A and Pentax M42 adapter jjdgti Sold Items 4 10-15-2010 12:34 PM
For Sale - Sold: Rare *Fast* Pentax-M SMC 35-70mm f/2.8-3.5 lens with case and box Nick Siebers Sold Items 19 07-20-2010 11:30 AM
All times are GMT -7. The time now is 04:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
