Hello all,
Here's my first post, but I wanted to show my findings for anyone who has experienced the same problem.
So I'm primarily a M42 mount lense shooter. I rarely use anything other than Old screw mount lenses. This is great but it poses a few problems when it comes to adapters.
I have gone through a aftermarket adapters which either fitted snuggly, but had loose threads or had tight threads but didn't fit snuggly at all, so I resorted to buying the Official M42 adapter ring from Amazon to see if it helped.
It worked great on my Takumars which sit snuggly against the body, but it was a problem for my Zeiss lenses which although screwing all the way in, showed a little movement that is in the design of the adapter.
So, rather than modifying the lense, I looked at ways of modifying the adapter to ensure a snug fit into the body and prevent any movement of the lense.
Below are instructions on how I fixed this. Note: I accept no responsibility for any damage to your equipment as a result of performing or using this fix.
This fix will use tiny strips of tape to increase the amount of friction between the body and the adapter.
Firstly, you will need:
- Duct tape
- Official pentax M42 adapter (not shown here)
- Small, sharp scissors.
- Small flat head screwdriver
Equipment
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
We will be sticking the tape on the outside of the adapter ring behind the little 'runners' shown below
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online. Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
So, firstly, we want to cut a piece of duct tape off and then, cut it down so it it approximately small enough to fit on the outer edge of the adapter ring.
Then stick this down on the outside of the ring as shown below, using the flathead screwdriver to ensure the tape is fully stuck down.
Do the above steps for all three of the runners found on the adapter, then, all you have to do is fir the adapter as normal, this will likely be a bit more snug than usual, but persevere and the adapter will clip in as normal. To take out the adapter, I recommend the removal tool supplied by many aftermarket adapters, or the usual pen method recommended by Pentax with a little extra umph.
And that's it, my Zeiss lense now has no movement whatsoever and so isn't a distraction when shooting.
I hope this helps. Any questions, do just ask and I will try my best to answer them.
