01-18-2017, 08:37 AM   #16
csa
csa's Avatar
You can't use both Arca-Swiss and Manfrotto at the same time, however.
If it's Arca-Swiss, it will work. If it's not, why would you buy it? A-S is such a widely adopted standard, surely there's a head with the required specs that is A-S compatible.
Indeed, Peak Design are pretty open about this. They try to make their gear fit, it's not their fault if Manfrotto have multiple "standards" and none of them are actually standard...
"You can't use both Arca-Swiss and Manfrotto at the same time, however."
Well, of course! I have two tripods, one has Arca-Swiss head, the other Manfrotto head; I would not be using both at the same time.
If you would read my last post before this one, I've purchased a NEST Gimbal head, that I'm picking up today!
01-18-2017, 10:29 AM   #17
bertwert's Avatar
QuoteOriginally posted by csa Quote
I believe bdery means that to use the Manfrotto QR you would have to bolt on the supplied adapter bits with allen keys therefore you can't move directly from Arca-Swiss to Manfrotto straight away without removing/attaching those bits.
01-18-2017, 10:40 AM   #18
bdery's Avatar
QuoteOriginally posted by bertwert Quote
Correct. It's a good plate but it's not magic
01-18-2017, 04:41 PM - 1 Like   #19
csa
csa's Avatar
Well darn, I want a magic plate!
01-18-2017, 09:03 PM   #20
bertwert's Avatar
Don't we all!
Your best bet is probably find a (cheapish?) arca head to replace the manfrotto head.
Or maybe use an L bracket... with a RC2 plate on the side and the AS plate on the bottom?
Actually it looks like you can get just a plate to replace the Manfrotto plate like this web post explains:
https://www.ocabj.net/manfrotto-rc2-to-arca-swiss-conversion/
01-18-2017, 09:32 PM   #21
csa
csa's Avatar
Actually, I don't use the Manfrotto tripod, as it's a very heavy beast. I'll be using my Sirui tripod with my new NEST gimbal head that I just got today, for photography.
01-18-2017, 09:43 PM   #22
bertwert's Avatar
Don't worry about it then!
Guess the compatibility is nice to have if ever needed
Have fun with photos!
01-19-2017, 05:47 AM   #23
bdery's Avatar
For people stuck with a non-standard head, there are also cheap conversion kits sold on eBay and other places. Just screw your tripod plate into a sort of claw which accepts Arca-Swiss. Then attach the non-standard plate to the tripod and leave it there.
capture, tripod, v2
T-shirt Contest Voting: General Designs Adam Travel, Events, and Groups 49 07-31-2016 04:38 PM
Peak Design Capture Pro Dropped My K-3 Today Doundounba Pentax DSLR Discussion 29 06-07-2016 11:58 AM
New Peak Design Capture Pro camera-clip owner raves about it fewayne Pentax DSLR Discussion 6 05-28-2014 03:14 AM
All times are GMT -7. The time now is 08:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
