01-13-2017, 08:15 AM   #1
UserAccessDenied's Avatar
Lost one of the rings from my K-3ii
I can't find anyone who sells replacements...
I have found some generic circle rings to put on there, but it's my OCD that's causing such angst!
Does anyone know where I can buy a replacement ring? (The triangle shaped ones for the sling mount/ camera strap)
I'd also need that little foam/leather buffer piece that goes around it.
01-13-2017, 08:29 AM - 1 Like   #2
UncleVanya's Avatar
QuoteOriginally posted by UserAccessDenied Quote
I lost one from my k-3, and I'd be equally interested.
01-13-2017, 08:36 AM - 1 Like   #3
Bengan's Avatar
There are loads on eBay strap ring pentax | eBay
01-13-2017, 08:45 AM   #4
Otis Memorial Pentaxian
They are sort of generic. I favor the Nikon variant that have the plastic bumper built into the "ring" to help avoid scratches.
01-13-2017, 08:52 AM   #5
QuoteOriginally posted by Bengan Quote
True, these would achieve the look... EDIT: Maybe they are all generic anyways?
I found one set with shim pads... I guess these could work.
I wonder if there is anyone making alternative options for the lug mount connection points. The Peak Design anchors won't fit in the lug by itself
---------- Post added 01-13-17 at 10:54 AM ----------
Where can you get these?
I guess if I replace both of them on my K-3ii I would be okay with it...
I use a Peak Design Slide strap anyways, so the sling attachment points are only really used on one side of my camera, the arca-swiss plate holds the other sling point.
01-13-2017, 09:22 AM   #6
Vintage Triangle Strap Lug Rings for Classic Nikon, Canon, Pentax, Leica | eBay
01-13-2017, 09:29 AM   #7
monochrome's Avatar
NEW Puleme Camera Strap Lug Ring(1 Pair) for Canon Nikon Sony Pentax Olympus etc | eBay
Puleme Triangle strap ring and leather bumper
01-13-2017, 09:35 AM   #8
ok I guess eBay is the way to go than.
I was hoping more for an option directly from a Pentax supplier. But I suppose it's all the same anyways?
01-13-2017, 10:05 AM   #9
Not a Number's Avatar
The vintage ones that stevebrot linked to look the the same as those on my Minolta MF bodies. I used to have spares around but have no idea where they are now.
If they are not proprietary like the lugs on the LX Ricoh probably buys them in bulk from some third party.
01-13-2017, 10:07 AM   #10
Hmm,
$9 for two rings...
There's a few antique shops near me that sell a ton of used film cameras. Most of which probably don't work since they are typically prices at or under $5 each.
Maybe I'll drive through town this evening and see if I can't score a few just for the rings. If so, I'll gladly share! haha
01-13-2017, 10:15 AM   #11
BigMackCam's Avatar
I've seen these on eBay and Amazon:
GRIMM D-SLR RF Mirrorless Camera Strap Lug Ring&Leather Cover Set (Black/1 Pair) | eBay
Not OEM, and a slightly different shape "triangle", but they look pretty decent.
01-13-2017, 12:29 PM   #12
csa
csa's Avatar
Glad you brought this point up! I'm going to get the Peak Design sling strap, so it's good to know I will have to change the "rings" on my K3 in order for the Peak to fit! Think I will go with the larger rings another member mentioned in another thread.
01-13-2017, 12:40 PM   #13
QuoteOriginally posted by csa Quote
Sorry, just to clarify! The Peak Design connectors DO work with the OEM strap rings. I just lost one of my rings, so the Peak Design connector won't fit through the tiny millimeter sized lug hole (the part built into the camera body itself)...
This would be ideal, to put the Peak Design connector looped through the lug hole on my K-3ii. Then I'd eliminate the ring altogether. The string on the connector is just a lad bit thick for it.
P.S. The Peak Design Slide strap is an amazing camera strap.
01-13-2017, 12:42 PM   #14
csa
csa's Avatar
Thanks so much for the clarification! Much appreciated. I'm anxious to try out the Slide strap!
01-13-2017, 12:51 PM   #15
One suggestion, when it's brand new it's prone to creasing if you fold it up to store it. Not a huge deal, but I wasn't expecting it.
It's almost like there's a super thin layer of memory foam in the part of the strap that hits your shoulder. So if you store it in your camera bag when not in use, just try to either roll it up, or curl it around the inside of the bag to not put a super sharp crease in the padding.
The crease eventually will ease out of the padding though.
Cheers!
camera, ebay, pentax, rings, sling, tripod
Why is this FREE Lens stuck to my K-3II........Chinon of all things ??? Dlanor Sekao Pentax SLR Lens Discussion 18 06-19-2018 01:12 PM
I didn't know f/16 was the farthest I can go on my K-3II Amoon Photographic Technique 38 09-16-2016 11:11 AM
Help me out in my white balancing on the K-3II Oakland Rob Pentax K-3 & K-3 II 3 03-16-2016 08:48 PM
Restoration of rubber rings of a 500mm series K cyberjunkie Pentax SLR Lens Discussion 5 02-22-2016 07:33 PM
Any reviews of the K-3ii by photo mags yet? tduell Pentax K-3 & K-3 II 12 07-13-2015 02:48 AM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
