01-28-2017, 11:41 PM   #1
Weevil's Avatar
Pentax Flash AF-540-FGZ II and Extension Cord (No 5P Sync socket)
Hi,
I used to use a AF-540-FGZ (version 1), with a extension cord F5P/F5P
and a Fg Hot shoe adapter
when I use my long focal lens for birding. The Flash is mounted above my lens, on a flash bracket and I use it with a flash extender (better beamer) to fill in the shadows when required.
The setup looks like that
I normally use HSS...
I recently aquired a used Version II to get weather proofing, and to my surprise, there is no 5P Sync socket on this flash???
Does that mean I need to put the flash on a Hot Shoe F now ???
Is there a way to make it working wireless or Wifi with the K-1 instead ?
Can't locate the right info....
Will I be able to keep HSS and P-TTL ?
Thanks for your insights
01-29-2017, 02:04 AM   #2
UMC
UMC's Avatar
QuoteOriginally posted by Weevil Quote
Simply yes. I was not aware of the fact that they dropped the 5p connector on the II version
No, unless you use 3rd party equipment for radio triggering. However, my knowledge is limited to genuine Pentax parts only.
01-29-2017, 06:49 AM   #3
This is one of the reasons I agonised over my flash purchase last year - version 1 actually had more to offer that I would use. Version 2 lost some features I would have liked, including self-regulating thyristor control for manual cameras But weather sealing was the overriding consideration, and the smaller size was also a clincher.
01-31-2017, 12:14 PM   #4
Just1MoreDave's Avatar
I have a Promaster-brand cable with a camera-style hotshoe socket on one end and the other end is just like a flash. It was adverstsed as Pentax-compatible and works fine. Although the flash protocols have changed, the socket and wiring haven't; this cable just extends the connections.
This should work the same way:
Vello Off-Camera TTL Flash Cord for Pentax Cameras (3') OCS-P3
A lot cheaper than the Hot Shoe F.
01-31-2017, 07:11 PM   #5
Would this cable also communicate working data for analogue TTL flash as supported by the *istDS?
01-31-2017, 09:25 PM   #6
I think I used mine with an AF400FTZ and a DS just fine, but I can't remember exactly when I bought it. I just tested mine with the version 1 AF540FGZ and DS and TTL mode gives me the same results as with the flash on-camera. The Vello one should be fine too.
02-01-2017, 01:53 AM   #7
UMC
UMC's Avatar
QuoteOriginally posted by Just1MoreDave Quote
... but I can't remember exactly when I bought it....
Well, as long as it is 5p compatible, it should be fine. According to what I can see on the pictures all contacts are there.
5p sync, cord no 5p, extension cord, flash, flash af-540-fgz ii, ii and extension, lens, pentax flash af-540-fgz, shoe, tripod, version
AF 540 FGZ II with cord or wireless ? BarryE Flashes, Lighting, and Studio 13 02-05-2016 07:50 AM
AF 540 FGZ II flash - $267 off at B&H Adam Pentax Price Watch 29 12-25-2015 10:54 AM
US Pentax Flash price drops (AF 360/540 FGZ II) Adam Pentax Price Watch 2 04-27-2015 09:33 AM
For Sale - Sold: Pentax AF-500 FTZ Wireless Flash, Sync Cord 5P, Adapters, Power Pack carpents Sold Items 4 06-07-2008 12:56 PM
All times are GMT -7. The time now is 07:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
