02-17-2017, 05:03 AM   #16
No - camera does not remain upside down if you use couple of accessories.
In action it can be seen in this video:
Pilze als Kunstwerke fotografieren! - YouTube
02-17-2017, 07:04 AM   #17
Not a Number's Avatar
The Manfrotto 056 3-D Junior has 180 on front and lateral tilt allowing you to flip the camera over. Not Arca Swiss plate though. I used to have the bigger version of this that they no longer make but someone broke into the trunk of my car and stole the tripod and head.
Manfrotto 056 3-D Junior Pan/Tilt Head 056 B&H Photo Video
02-17-2017, 07:26 AM   #18
QuoteOriginally posted by WPRESTO Quote
...Alternatively, a Manfrotto multi-purpose clamp could be fitted with a ball head and clamped low on a tripod leg. Disadvantage: the ball head would projecting laterally and slightly upward, an awkward orientation to get the camera pointed exactly as you want. Advantage: the Manfrotto can be clamped on a bar or a flat board. I used one clamped on a little bridge which positioned and held the camera sturdily where I could not position a tripod...
all of these ideas are good but this is the one I've used the longest...Manfrotto 155 Double Ball Joint Head with Camera Platform and heavy and it works
02-17-2017, 07:59 AM   #19
Saltwater Images's Avatar
You may also want to consider the Vanguard Alta Pro 263ab SBH100. I have been using this robust, well made tripod for 3 years in all kinds of conditions. There is a youtube review by Matt Granger here:
02-17-2017, 09:59 AM   #20
jab2980's Avatar
QuoteOriginally posted by C_Jones Quote
I have the Sirui EN-2004. The following is a quote from its description on how it is capable of low angle or macro shots. Also below is a shortcut to the tripod offered on Amazon. There is also a smaller similar version, the SiruiT-1005X. Its product page shortcut is below also. I use the Sirui K-20X ballhead which is rated for 55 lbs..
"By unscrewing the hanging hook from the bottom of the center column, the column separates and the short center column remains on the tripod, ready to take macro or low angle shots or you can invert the center column and shoot from underneath the tripod."
https://www.amazon.com/gp/product/B00IKHRRFG/ref=olp_product_details?tag=pen...20&ie=UTF8&me=
https://www.amazon.com/Sirui-T-1005X-5-Section-Aluminum-Tripod/dp/B004WY7TL8...eywords=t-1005
I've got the M-3004X with K-10x Ball Head and it works brilliantly. It allowed me left me much more dry and made it easier to get this shot:
02-17-2017, 11:07 AM   #21
BakDinitzen's Avatar
Have You looked at the Vanguard Alta Pro 263 AT?
http://www.vanguardworld.us/photo_video_us/alta-pro-263at.html
02-17-2017, 12:06 PM   #22
Quartermaster James's Avatar
If you don't mind old school bomb proof construction, you can invert the center column on Tiltall tripods.
02-17-2017, 01:52 PM   #23
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by ChrisPlatt Quote
Have you looked at Benbo tripods
+1, beat me to it.
Benbo Clasic No 2 reviews - Pentax Camera Accessory Review Database
02-17-2017, 03:56 PM   #24
Canada_Rockies's Avatar
Have you looked at Benbo tripods (not to be confused with "Benro")?
My wife has a Benbo Trekker. It is amazingly flexible in configuration.
Chris
I have a Benbo Trekker. The only caution is to be VERY careful when loosening the clamp, since that undoes everything except the center column slide. I've used it for a "selfie" on a 60 degree slope with a K10D + grip + DA* 16-50 mounted. Held fine. Three different leg lengths and really weird angles, but I don't know of anything else that would have held the camera there.
02-18-2017, 06:26 AM   #25
This is what I use
This is my normal usage of the A* 400mm f2.8 , a Bogan 3033 tripod with the Monfretto 393 head. The need for a lower mount arose and this is what you can do with this head. It is heavy, difficult to use until you get use to it, but it works. No center column adjustment this way, adjust the camera height above ground with the legs.The 393 head screws directly on to the top or bottom of the column with no adaptors needed. Please excuse the poor quality of the photos, they were taken for illustration purposes.
PENTAX *ist DS  Photo
02-18-2017, 09:42 AM   #26
ChrisPlatt's Avatar
FWIW I could never consider owning any "Benro" product.
The name is a blatant rip-off of Benbo.
It's just too similar to be a coincidence.
I hope Benbo sued their pants off!
Chris
02-21-2017, 07:49 AM   #27
PEG Moderator
Kerrowdown's Avatar
FWIW I could never consider owning any "Benro" product. The name is a blatant rip-off of Benbo. It's just too similar to be a coincidence. I hope Benbo sued their pants off! Chris
Due to the unique way the legs and column lock, i.e. one bent bolt, which is where I believe is where the name comes from BENt BOlt. Originally based on a early machine gun tripod mounting from WW1.
02-21-2017, 09:04 AM   #28
QuoteOriginally posted by Kerrowdown Quote
@OP: Go to BH Photo or Adorama's webstores and search on "reversible column" to get a list of choices.
03-01-2017, 04:24 PM   #29
Ex Finn.'s Avatar
+1. Manfrotto super-clamps Manfrotto 035RL Super Clamp with Standard Stud 035RL B&H Photo are very handy.
I use one with a 1" ball RAM mount RAM Mounts - Mobile Mounting Solutions that has very good articulation. Not many things that this combo can not do.
PENTAX K-5  Photo
03-31-2017, 12:34 PM   #30
ramseybuckeye's Avatar
I have a MeFOTO DayTrip Tripod that can get really low with excellent stability. I also have a Manfrotto Super Clamp with a small ball head attached which can be handy if you have something to attach it to. I have used my large Induro tipod with the center column reversed, but I used the camera upside down, or in portrait orientation.. If you really want to go light, use a beanbag, that can be very effective, cheap, and lightweight.
base, benro, bottom, button, center, center column, column, fingers, jam, mechanism, photography, press, stuff, tripod, tripod with upside-down, tripods, upside-down
Landscape Upside down Artgraf1981 Post Your Photos! 12 04-27-2016 07:16 AM
Upside down? vinni Monthly Photo Contests 22 04-06-2015 04:23 PM
Upside down PixelBucket Monthly Photo Contests 3 04-03-2015 01:29 PM
Center Column for Manfrotto 3001 skid2964 Pentax Camera and Field Accessories 3 06-21-2013 05:30 PM
Horizontal Center Column Tripod Suggestions? iamin Pentax Camera and Field Accessories 14 11-22-2011 06:13 PM
All times are GMT -7. The time now is 12:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
