02-20-2017, 09:37 AM - 1 Like   #1
pacerr's Avatar
Cable release options
I miss the mechanical cable release feature and the ability to use a really looong pneumatic release.
My solution's to use 8-32 thread nuts epoxied to the camera top as an anchor point for various DIY brackets -- one for the cable release is a section of aluminum U-channel with the top arm extending over the shutter button.
Another holds a curved fiber optic cable in place over the front IR window when the camera's not within line-of-sight. Nuts may also be glued to the flash shoe protector if that's more convenient or cosmetically acceptable. Use your imagination.
I'm experimenting with using threaded shutter release buttons from older film cameras attached in place over the current smooth buttons.
Bracket adapter anchor points - 8-32 nuts
Also, note the small rubber grommets on the shutter button (and other places not shown). My finger tips have become numb owing to nerve damage and this helps locate flush controls. A larger grommet around focus/aperture rings helps on occasion too.
02-20-2017, 09:48 AM   #2
Thagomizer's Avatar
Neat, simple idea. Could you post some pictures of the brackets?
02-20-2017, 09:51 AM - 1 Like   #3
pacerr's Avatar
Later -- I'm not 'co-located" with 'em at the moment. Here's the general idea for the cable release.
Can be easily made from various sizes of plastic or aluminum U-channel, cut up plastic bottles or bent-to-fit from metal scraps. A paper punch may be enough to make holes in thin metal. Crimped edges can stiffen thin metal.
PENTAX K-5 II s  Photo
02-20-2017, 10:38 AM   #4
I bought one for a Lumix LX5.
Kiwifotos CR-LX5 Mechanical Cable Release Adapter for: Amazon.co.uk: Electronics
Works well.
Update:can still be found eg on ebay, JJC is one marque.
02-20-2017, 10:49 AM   #5
pacerr's Avatar
Yeah, neat-o, but . . .
"Currently unavailable. We don't know when or if this item will be back in stock."
I imagine the need to custom "print" for each camera dimension plus the small market conspires to defeat this sort of accessory.
02-20-2017, 11:07 AM   #6
roberrl's Avatar
Good candidate for 3D printing ? The flash mount part would be standard and then two dimensions to locate the shutter button.
anchor, button, buttons, cable, cable release, nuts, release, shutter, tripod
Shutter Release Cable P30 35Shutter77 Troubleshooting and Beginner Help 19 12-15-2016 04:30 PM
delay shutter release options for 67 and 645 LFLee Pentax Medium Format 4 01-23-2015 12:40 AM
DIY DSLR K-X “Cable” Cable Release trailrider Do-It-Yourself 4 07-11-2012 10:18 PM
Cable release options? NoobPhotographer Troubleshooting and Beginner Help 14 05-11-2011 01:39 AM
ZX-L cable release options? scottax1 Pentax Film SLR Discussion 2 06-27-2007 06:59 PM
All times are GMT -7. The time now is 08:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
