03-08-2017, 01:22 PM   #1
Questions Pentax 3/21 Exposure Meter
Hi folks, I've looked around the forums and the web and I cannot seem to find out much about this meter.Do any of you have more specific knowledge of it? When it was made? It's uses. Does it have any use for a modern digital photographer? It needs new batteries but is otherwise in remarkable shape. Does it have any value? Anything you could tell me would be appreciated.Thank you.
PENTAX K-3  Photo
PENTAX K-3  Photo
03-08-2017, 02:24 PM - 1 Like   #2
UncleVanya's Avatar
James's Light Meter Collection: Honeywell Pentax 3/21 Spot Meter
http://www3.sympatico.ca/dschneller/manuals/PentaxSpot321.html (linked in the one above also)
03-08-2017, 04:28 PM   #3
Thanks UncleVanya that's boat loads of information, it's much appreciated. I'm still wondering if it would be of any use nowadays or if it's something I should put in the Marketplace for collectors of these accessories.
03-08-2017, 10:30 PM   #4
UncleVanya's Avatar
QuoteOriginally posted by Cardinal15 Quote
Reading the article it seems like a nice unit with good ergonomics and relevant to those who enjoy using a spot meter. The biggest issue seems to be one of the batteries being hard to replace.
---------- Post added 03-09-17 at 12:39 AM ----------
Upon further reading a px23 can replace the difficult 5.6v and the 412 battery isn't hard to find.
03-09-2017, 07:25 AM   #5
pacerr's Avatar
If the meter reads 'reasonably' compared to a known good meter it's "usable". But be prepared to spend a lot of time calibrating it to match the meter results you're accustomed to with your TTL metering cameras.
A quick check is to meter the out-of-focus northern sky with your TTL spot meter and your other unit(s) and compare the results. Also expect there will be gradual changes as batteries age and possibly even with temperature change.
Some types of meters are more sensitive to 'light' outside the visual spectrum which isn't a problem when incorporated into a calibrated system but can give inexplicably different results than expected.
Also keep in mind that a spot meter can be a real PITA unless the light and the subject are relatively constant.
03-09-2017, 07:30 AM   #6
Hi Cardinal,
I refurbished one in 2013 including re-designed electronics.
Vintage Spot Meter Refurbish | APUG.ORG
pentax 3/21 exposure, questions pentax, tripod
67II: What tele lens would turn my AE 67 Finder Meter into a 1 spot meter? jt_cph_dk Pentax Medium Format 18 02-01-2017 11:24 PM
Questions, questions, questions (PZ-1 and P3) dakight Pentax Film SLR Discussion 12 09-06-2014 06:23 AM
Honeywell Pentax 1/21 Meter SOldBear Pentax Camera and Field Accessories 7 04-06-2013 09:01 AM
How to meter if you don't have a light meter? LFLee Pentax Medium Format 25 02-09-2012 11:45 AM
DA 21 LE vs CARL ZEISS DISTAGON T* 21/2.8 ZF yipchunyu Pentax SLR Lens Discussion 4 10-06-2009 06:51 PM
All times are GMT -7. The time now is 06:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
