03-22-2017, 08:00 AM   #1
Camera Holster
I have a Pentax K-1 (and K-3) with battery grips. They can be quite heavy when walking around for hours, so I'm looking for a camera holster to support the camera better than having it around my neck, which has caused me some pain, literally (and visits to the chiropractor). I'd like to find something that I cause use when traveling and maybe connect another lens to instead of carrying my bag everywhere too such as on hikes. I'm traveling to Europe in June and want to get something now to get used to it. Any suggestions??
03-22-2017, 08:33 AM   #2
I have four
a very old tarmac..body and two smallish lenses or a 55-300
a clik that I use for a k3 with a tamron 70-200 (hood reversed)
a large kinesis that holds a body and a sigma 150-500 (hood reversed) or the 70-200 da300 with hood attached
a think tank 50 v2.0 holds a body and the same assortment of larger lenses
the kinesis and think tank will handle my k3s with a grip
all the holsters are well made and have taken a lot of abuse
I have four brands because I buy them on sale or clearance
a lot of folks like the lowepro holsters
good luck
03-22-2017, 09:31 AM   #3
Seeker of Knowledge
aslyfox's Avatar
Question for you
Is your camera hanging straight down from your neck or is it cross the shoulder and hanging near the opposite hip
I use a sling hanging across my left shoulder and hanging off my right hip and I have a hand grip as well.
the cross body method, for me, takes a lot of the weight off of the neck and onto the stronger shoulder
It allows me to use the hand grip to take all or some of the weight off the shoulder when I need a rest.
I also will cradle the camera and lens in my arms to change up the weight
All of these techniques helps me carry my K 3 + battery grip and the Pentax 150 - 450 mm zoom
The sling would allow another camera but I don't think my body would
It is an op/tech usa utility sling, the hand grip is a joby ultrafit hand strap with ultra plate
03-22-2017, 10:45 AM   #4
I appreciate the replies. Typically my camera hangs off my neck, and I'm also packing a camera backpack bag. I need to manage the weight and also secure the camera.
03-22-2017, 10:53 AM   #5
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by bpcarlson Quote
to each his/her own
only you know what is best for you
FYI
I put my back pack on first and then sling my camera and lens over my shoulder so I can carry the back pack and sling. when I don't need the whole gear, I use a smaller camera bag for extra lenses and filters etc and do the same, the camera bag slung over one shoulder cross body and the camera and lens over the opposite shoulder
03-22-2017, 02:18 PM   #6
Saltwater Images's Avatar
How about the SpiderPro system?
Spider Camera Holster SpiderPro Single Camera System 100 B&H
03-23-2017, 05:39 AM   #7
bdery's Avatar
My two suggestions would be to either use s sling strap, or an attachment like the Peak Design Capture clip (or sturdier Capture Pro). It works amazingly well.
03-23-2017, 05:50 AM   #8
Seeker of Knowledge
aslyfox's Avatar
I am experimenting with a method to keep my set up from swinging at the hip.
since the hand strap and the utility sling both attach to the same side of the DSLR, it leaves the other attachment in the other side of the camera free. I have run a Joby Tether Camera for Pro Sling Strap
Joby Camera Tether for Pro Sling Strap, Charcoal JB01307
from the other attachment point. This allows me to tether the camera to another support point such as a belt loop restrict the swing
the problem is that in order to use the DSLR, I have to unhook that from the belt loop.
so if I am bothered by too much swing I just restrain it with my hand (especially since I often wear sweats or shorts without belt loops)
of course, any parachute cord + hook could be used for the same idea you don't have to use the joby product if you don't want to pay for it.
I have also secured it to the sling so I have a back up if the sling attachment fails
03-23-2017, 09:32 AM   #9
onlineflyer's Avatar
Cotton Carrier has two holsters that might fill your need. The 1st is the CCS EV-1 that attaches to the backpack strap.
CCS EV-1 StrapShot Holster, Cotton Carrier StrapShot - Cotton - Camera Carrying Systems
The 2nd is the CCS Endeavor hip holster.
CCS Endeavor Holster, Camera Holster System - Cotton - Camera Carrying Systems
03-23-2017, 09:32 AM   #10
bdery's Avatar
QuoteOriginally posted by Aslyfox Quote
I'll repeat the advice I wrote above. Get a Capture Clip, maybe with the ProPad to keep it more stable.
03-23-2017, 10:00 AM   #11
jab2980's Avatar
I considered this for event photography, however the major drawback with this type of system is that it can/will pull your pants down... especially for those who don't have a small/flat belly. I use a Peak Design clip that I attach to my backpack strap for hiking when I'm not using my tripod. For events, I'm using a HoldFast CameraSwagg strap system.
03-23-2017, 10:07 AM   #12
Seeker of Knowledge
aslyfox's Avatar
QuoteOriginally posted by jab2980 Quote
. . it can/will pull your pants down... especially for those who don't have a small/flat belly. . . .
sounds like you know me way too well
______________________
question for those who use something other than a sling
I can understand that a clip system whether attached to a belt or a back pack strap would be helpful but I wonder how it works with a DSLR and a large lens??
what is the largest lens you folks feel comfortable using with your clip system???
I am not only talking weight but physical size as well.
I am looking for "real life" experience in hope that will help the OP and others.
I can carry my K 3 + HD Pentax-D FA 150-450mm F4.5-5.6 ED DC AW + HD Pentax-DA 1.4x AW AF Rear Converter
without much of a problem but you certainly don't forget that it is there
03-23-2017, 12:20 PM   #13
bdery's Avatar
Well, a 150-450 hung on a belt clip is asking for trouble. These systems are better suited for small to medium lenses.
With medium lenses (my largest lens is the 60-250), I attach the lens via its tripod foot. That's true whether I use the Capture Clip or a sling strap. Both the Capture Clip and the Peak Design Slide strap are rated for 200 pounds, the same holds for the Op/tech I used before. Holding the system by the lens makes more sense.
However, for larger lenses such as the 70-200 or 150-450 I don't think the Capture clip would be a good match. Those lenses are just too cumbersome. Using a sling would work (but would not be comfortable with the 150-450, by experience that one should live on a monopod).
The Capture Clip is meant for traveling light, not exactly for carrying the 150-450...
03-23-2017, 12:35 PM   #14
bobmaxja's Avatar
I am using the Cotton holtster with my K-5 and this is the best accessories I ever bought
This is the one I use not the one above
CCS Wanderer Holster, Cotton Carrier Side Holster - Cotton - Camera Carrying Systems
03-23-2017, 04:09 PM   #15
jpzk's Avatar
Most interesting and informative thread!
I am looking for an "add-on" clip/holster to take the weight down from carrying my gear (cross-wise) around my neck/shoulders.
Some great suggestions here.
Cheers!
camera, holster
Click - cool new camera holster on kickstarter with goodies for first 100 i5_david Pentax Camera and Field Accessories 7 04-10-2016 07:46 AM
Camera holster dilemma 'CapturePro' vs 'B-Grip' ts357 Pentax Camera and Field Accessories 10 03-09-2015 11:51 AM
Camera Holster Bag woodywesty Pentax SLR Lens Discussion 14 11-04-2013 02:24 PM
Capture Camera Clip vs Spider Pro holster DaveR Pentax DSLR Discussion 3 01-11-2013 03:08 PM
Spider Camera Holster review on Engadget - Be like the cowboy you always wanted to be Livewireshock Pentax Camera and Field Accessories 13 03-10-2010 03:51 AM
All times are GMT -7. The time now is 07:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
